Results 11 to 20 of 39
Thread: Project Turbodiesel
    Gosford Central Coast NSW
    yea you oughtnot have any trouble getting int shaft bearings - will be similar for all the diesel engines - 1.5/1.6/1.9...even 2.5..maybe.
    cool project man! BTW -is yours solid lifter or hydraulic?
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Apr 2006
    Melbourne, Victoria
    It has the mech head. This afternoon Im going to visit the machine shop for the measurements of the bores and crank. Then its a waiting game for the pistons and bearing to arrive. While im waiting i think i'll paint the block. Maybe mars red to match the car. Any thoughts on this very important decision?
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Jun 2007
    Eastern Suburbs Melbourne
    something other than black so you can see oil drips etc.
    just imo anyways.
    i like volkswagens
    Apr 2006
    Melbourne, Victoria
    Are 200mm clutch/flywheels available in australia?
    Jun 2007
    I've never heard of 200mm clutch's. Heard of 210mm and 190mm though,.
    i like volkswagens
    Apr 2006
    Melbourne, Victoria
    I think the 1.6D and TD has a 200mm clutch as standard. Are 210mm clutch/flywheels available in australia?
    Apr 2006
    Melbourne, Victoria
    The gearbox i have is a 4T code 020 which according to this table should have a 190mm clutch/flywheel. I just hope my 1.5D clutch fits up to the 1.6 Crank! Im on my way to the machine shop with clutch in hand to check.....
    http://www.4crawler.com/Diesel/VW_02...smission.shtml
    Oct 2006
    Well if u need a 200mm clutch ive got one spare which is not needed. Bought it new thinking it was a 210mm one but unfortunately not. And yeh they only fit the mk2 diesels.
    210mm is the mk2/3 petrol model which u can find pretty easily.
    Apr 2006
    Melbourne, Victoria
    Time for a progress update.
    Mostly it has been ordering/sourcing parts and building the motor.
    This box from GAP contains ball joints, strut tops, coolant expansion tank with level sensor. I also have a set of engine mounts and urethane bushes from a previous order.
    And heres the motor internals, piston set, bearings, small end bushes, valves and oil pump. It doesnt look like much but this came to just under $1000! (including some gearbox goodies not pictured).
    The engine has been bored and will soon have the required machining work done to install oil squirters.
    I have been busy at pickapart picking up rear drums, booster, mc and gearboxes with flywheel/clutch from Seats. I got a diesel style oil cooler too. My garage is full of greasy junk right now. I cant wait to start putting this all together!
    Aug 2006
    Melbourne VIC
    Good work! Make sure all that greasy junk become nice clean parts before they go in
