Results 21 to 30 of 39
Thread: Project Turbodiesel
  1. #21
    Apr 2006
    Melbourne, Victoria
    Some turbo candy...
    Its a k14 off a 1.6 or 1.9TD. I have a rebuild kit and will be stripping it this evening. Pics to follow....
    In other news, I have a set of oil squirters that are going into the block
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
  2. #22
    very nice work mate,
    i got the same manifold...in pretty good condition.
    pm if interested.
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
  3. #23
    Apr 2006
    Melbourne, Victoria
    Room for a downpipe?
    Oil return line comes up a bit short....
    K14 comes apart
    Not much to a turbo, so far anyway. Still have to strip the bearing housing.
    shaft play
    anyone care to suggest if this is acceptable for a bush style bearing turbo?
    Next I'll be stripping the bearing housing and replacing the bearings and seals.... I think I'll have all the iron blasted to remove the rust too. More photos to follow.
  4. #24
    Gosford Central Coast NSW
    good work mate.
    that much shaft play is probably almost normal (remember others looking at those pics that the k14 has a tiny little compressor wheel, much smaller than seen on petrol car turbo's).
    as long as its sufficiently small that the wheel dosnt go near the housings when fitted and torqued properly, you're OK.
    that oil return looks like the one for mounting the turbo in the "down" position (manifold flipped).
    good stuff mate, nice when things are moving along
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  5. #25
    Nov 2005
    newcastle
    good stuff mate.
    The downpipe has to do a quick downwards U turn and then head straight down. We modified the linkage on my mk1 to give the downpipe a bit more space.
    keep up the good work.
    Mike
    TDI mk1 on the road!!
  6. #26
    Apr 2006
    Melbourne, Victoria
    Thanks guys,
    the turbo is off a 1.9TD which drains the oil back into the side of the block through a banjo fitting. I was hoping that it would reach one of the unused engine mount bolt holes in the block casting so i could simply drill and tap it for a banjo bolt but its too short. i should be able to have a longer section of braided hose fitted to it though.
    I visited the motor on Saturday and was pleased to find a ceramic coating on my piston crowns and a friction coating on the skirts! Also, the cracks between the valves have been welded and new valve seats installed. Remaining is the installation of oil squirters, honing, and assembly of the block and grinding of the seats, skimming the head, installing the prechamber cups and assembly of the head!
    Other bits that i need to sort out are:
    Injector lines to clear the TD injector pump
    Turbo oil supply
    Bigger radiator
    Downpipe for the k14
    pre and inter plumbing
    EGT, oil pressure and oil temp gauges
    New injector nozzles
    rebuilt injector pump
    intercooler
    And the car overall needs:
    Rear swaybar fitted
    suspension reinstalled
    new ventilated discs
    new DB401 pads
    new front brake hoses
    front sway bar
    stereo capable of cutting through the clack
    100mm inner cv joints fitted to the mk 1 axles
    I have a cordoba booster, rear brakes and 22mm master cylinder ready to go, along with new Sachs dampers, king springs, rack ends, ball joints, urethane bushes and a toledo gearbox with 24mm input shaft and 210mm clutch
    For the body i have gti flares, grill and a large new duckbill spoiler (which id gladly swap for a thin one). I also will fit an adjustable passenger side mirror that i have lying around.
  7. #27
    sounds like you've got all the bases covered mate, great stuff!
    Quote Originally Posted by hiho View Post
    i was dreaming about this the other day!!!!!! Im soooo jealous!
    '99 A4 Quattro 1.8T
  8. #28
    Apr 2006
    Melbourne, Victoria
    No more floppy side mirrors!
  9. #29
    Aug 2009
    Vancouver Island BC Canada
    Oil squirters
    Great project, I am interested in the machining of the oil squirter ports.
    I guess you have an ME block which did not have the ports drilled into the oil gallery. How did it go, did you have the machine shop do it or did you do it yourself. Did you use an old block to determine the location and angle or what ?
    Do you really think the squirters were necessary given that you did the ceramic coating and don't plan to really push for high performance.
    Peter
    Grumman Kubvan, 1.6L TD
    Exploring the Salish Sea
  10. #30
    Oct 2006
    If your gonna get a new line you might as well put the return in the oil pan and get a bung welded up. That way u can also sell that oil return to me lol
    For injector nozzles i found this site a while back too:
    http://www.veg-injection-service.com...7ab791801744e8
