also my car ran out of electricity on the way home, so a new alternator is needed, alla in all not a good night![]()
here goes.... the EPIC FAIL:
- L/H Stop light
- Cambelt cover
- L/H park light
- indicator flashing rate what the hell?
- exhaust too loud
- no polution pump
- none pollution engine (wrong model engine) How so? Its still the same engine code
- wrong craby surely thats not a RWC issue?
- H/Brake cable hanging
- bumper not fitted properly they are plastic bumpers
- L/H rear tyre
- Rust L/H sill and floor crushed both sides I have already fixed the rust in this pillar and its just the sill that hangs down that is bent cos someone jacked off those instead of the proper jack points
- front brake hoses
- R/H seat belt
- R/H door adjustment how can you seriously ping someone for this, it just doesnt shut it you push it sofetly
personally some of the stuff there is bollocks, someone please tell me im right in saying this.
that sucks man! makes me sad
ell if ya need a hand i can come help! (aslong as you have a heater) LOL
That's not all bad.
This place seems a bit excessive both my '79 golfs got through RWC with no emmisions kit on them at all! They both started off life a diesels too and they were both RWC'd with petrol motors. One of them has a KJet 1800 in it that passed rwc! No air pumps in sight! This place seems pretty @nal!
- L/H Stop light - Easy Fix
- Cambelt cover - I've got one here with all the mounts(It's red!
- L/H park light - Easy Fix
- indicator flashing rate what the hell? Too slow or too fast?
- exhaust too loud - How did you not see that coming?!
- no polution pump - What year was this car?
- wrong craby surely thats not a RWC issue? Only if it doesn't meet emissions standards.
- H/Brake cable hanging -Easy Fix
- bumper not fitted properly they are plastic bumpers - Why?
- L/H rear tyre - Only got yourself to blame for that one!
- Rust L/H sill and floor crushed both sides I have already fixed the rust in this pillar and its just the sill that hangs down that is bent cos someone jacked off those instead of the proper jack points - Bend it back and add some bog and undercoat.
- front brake hoses - These things are actually important - get new ones!
- R/H seat belt - Could save your life one day!
- R/H door adjustment how can you seriously ping someone for this, it just doesnt shut it you push it sofetly - Just fiddle with it for 15 min and grease the latch.
Getting around the polution pump argument is going to be the tricky one.
Might be simpler to fix the easy/safety stuff and try again elsewhere.
Pete
I know some of it is crap.. But there's nothing you can do about it. Just set it all up the way THEY want, get it passed, then go nuts..![]()
I think its time to call the dodgy brothers and get a lebo rwc...
But try and make it the best then off to see the dodgy bros![]()
What pete said... ^^![]()
thats very good advice pete! i can't believe you had a diesel and they passed it with a petrol!MAD! where did you get it done...maybe josh needs to hit them up?
