I never drove a MK1 with RHD, but I heard that the braking effect is very badly. This based on the bell cranks or similar, which put the braking-pedal to the right side. Exist there any solution for make this better or what do you plan?
Basically. msichas right, a big drop sheet and some tape will give you a "clean" environment.
The only issue is air flow. When I painted mine in the garage, there was little, to no airflow while we were painting. and as was evident when we opened the roller door, a bucket load of fumes and paint dust flew out! So if you do want to paint in the garage, be prepared to do alot of sanding back, as you will find that when you're painting the back of the car, the paint dust will fly across the car, and stick ontop of the front of the car, which gives it a rough finish, and means you need to do a bit of sanding back.
Um, so yea, it defiantly is do-able, and providing you do enough layers of paint (i'd go 3 at least for me next spray job, 4's even better, bascially, do 1 layer going over all the corners first, then a full layer) rubbing it back will bring it up good. um, yea, I'm sure I've forgotten a few things, but if you even have any questions, don't hesitate to ask!
oh and go for a 2.5 HP compressor at least.
Any idea what CFM we should look at?
I work at Super Cheap Auto head office, so I'll get all the inside goss lol!
A mate from work just painted his sons car (he's up on all this paint and panel stuff, and not a hacker). And he was telling me what size his is, so i'll find out tomorrow and let you know, if someone doesn't before me. But basically, the bigger the better really. You just need a compressor that can supply more volume than what the spray gun will output.
No prob.
Any idea where the VIN number would be, or do they even have one (slightly stupid question)?
yea. I think a 2hp will make at about 90 cfm, and you need up about 120/130 I think. but don't quote me. All I know is that I used at 2.5, and it worked..![]()
