Page 2 of 13 FirstFirst 123412 ... LastLast
Results 11 to 20 of 130
Thread: NZ: MKII 3 Door Project Car
    Feb 2008
    New Zealand
    Fizz and I cracked in to it and made some progress!
    Did some panel beating to correct some retarded looking rain tray
    Cleaned fluffy deadening on the roof
    Cars almost ready for re deadening and when i can source a loom that can start being laid
    Got to attend to some minor surface rusting an cut and repair the windscreen seam.
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
    Feb 2008
    New Zealand
    Cool
    Not much Changed today.
    Ordered a Small Sandblaster so i can attack things like the minor rust around the windscreen and clean the old paint off the seat rails etc etc.
    Trying to decide on a color I am finally going to paint the car (in a few months time when this has progressed further down the road.
    Plans this Week
    - Remove; Front Fenders, Doors, Boot lid and various other fittings to be taken off too.
    - Install some calipers & Pads on the rear so the hand brake can actually be utilized
    Other Plans in the pipeline
    - Hopefully start forming replacement sections out of Panel Steel to weld back in where the frame has rotted slightly around the Windscreen.
    - Start lifting off the rest of the sound deadening probably with the use of Dry Ice
    - 2010 Golf R
    - 1997 Golf VR6
    nice one mate, keep up the good work
    Jan 2012
    Bentleigh East, Melbourne, Vic
    I too am enjoying this....nice job
    Polo 9n3 GTI
    Feb 2008
    New Zealand
    Quote Originally Posted by clicht View Post
    Quite Happy with todays Haul actually..
    Secured the following pieces of interior Trim
    - Pair of A Pillars
    - Pair of C Pillars
    - Pair of C Pillar Bases (Parcel Tray Holders)
    Still hunting for the Headliner and Electric Windows and hard backed door cards.. front and rear.
    - 2010 Golf R
    - 1997 Golf VR6
    Nov 2007
    Yallambie
    Did you remove the whole wiring loom, if so how did you get it all though the bulk head and where are you going to get a new one from?
    I am here: http://tapatalk.com/map.php?4asuzi
    500 Series Hino - 99 V6 PASSAT Daily Driver
    84 MK2 GTI 16v - 88 MK2 GTI 8v Donor
    Feb 2008
    New Zealand
    Quote Originally Posted by moostin View Post
    Hey Chief from Memory Most of it was already gone anyway.
    I have a MKIV DBW Loom waiting to be removed from a Wreck at the local wrecking yard... Im just waiting for them to call me and let me know when I can come and pull it out!
    Just retaining the MKII Plug ends for the Tail lights/Interior Lights/Door Switches etc..
    The MKII Wiring now is all a bit decrepit and perished to re use any way.
    On another note
    Im down to 4 Colours I like that I will more than likely paint the car in!
    - 2010 Golf R
    - 1997 Golf VR6
    Oct 2011
    Auckland, New Zealand
    Hi Anton! Some good progress on this bro!
    Feb 2008
    New Zealand
    Can not wait for saturday to come around
    Got a Fair List to achieve by the days end so far!
    - Get the Dry ice on Friday and Destroy the rest of the old Sound Deadening on saturday morning
    - Remove Front Guards
    - Remove Front Hubs and press out the decrepit axles
    - Sandblast anythign that needs it
    - and finish Shaving ugly brackets off the engine bay!
    If time allows make patch template for windscreen rust repair.. and start preparing the patch peice out of panel steel..
    Thats probably a fairly ambitious list.. but this project is early days so am still learning how to guage/manage time
    ---- On another note Lots of Goodies arrived today (un-important **** but goodies none the less!!)
    Big Bumper Bits
    and also secured a set of 90s spec arches and Side Sills to come here from the UK!
    - 2010 Golf R
    - 1997 Golf VR6
    Feb 2008
    New Zealand
    Well Saturday came and went, and I feel that Fizz and I achieved a fair bit on the car Started around 9ish finished the day around 5:00pm
    Still right at the beginning of the prep work stage but i feel this is super important for a better finished result.
    So yeah its taking ages but what the hell..
    We ran down the road to BOC Gasses and grabbed about 15kg of Dry Ice (Solid CO2),
    with the intention of removing as much of the manky and old sound deadening that was stuck-fast to the floor pan.
    Poured it on in to all the foot wells and kept on waiting a little bit then moving the Dry Ice and then whacking with the Mallets... It didn't work, so we decided to leave it to "cook" ( so to speak ) for 20minutes and to kill time decided to start preparing the Front Guards/Arches for removal....
    If you leave the Dry ice to sit then give it a belt with a Rubber or plastic mallet you will be surprised how the old crap just shatters and can be picked/swept up and thrown away!.
    Here are some Shots of the Progress of the Removal and the finished result
    All in all pretty good cleanish and not as time consuming and messy as a scraper and heat gun method
    (Which is still needed to finish of the tunnel Area!)
    Turns out making dry ice bombs is extremely loud... fun... and easy to make!!!!
    Was good to get the Fenders/Guards off too. really expose this bad girl up...
    Man the manufacturer went overboard with the Underbody Silicone ****!
    Only discovered a pretty minor looking rust under the Passengerside Guard
    The Next Job was to get the Driveshafts out of the Spindles... ( I tried removing these the other day and left the shafts soaking in CRC for about a Week, and they still didn't budge!) and even using a puller tool they wouldnt move at all
    (Copper Grease goes a long way when you are assembling parts)
    Removed the Strut from the Spindle
    Removed Tie and Ball Joints
    Removed Spindles and Drive Shaft away from the Car in one
    Had to apply nearly 15 Tonnes (Indicated by my Hydro Press) just to the god dam old Shafts out of the hubs
    Decided I'm going to order all new stuff for most of the part we have been working on thus far.
    So that means...
    - New Tie Rod and Rack Ends
    - New Rotors
    - New Calipers
    - New Ball Joints
    - New Wheel Bearings etc
    And While we were at it we thought f*^& it less remove the subframe too... was we can tidy that up as well!
    New Paint / re movver
    The Shell is now carted around with the use of a trolly jack and pallets
    Next Weekend will Probably entail removal of the Rear beam axle to give that a tidy up too!
    New Bearings and probably a powder coat..
    Going to have to attend to the Rust as well but for the time being i have doused it in Rust Converter untill i have a day good enough to sand blast it back and see how serious or not it may be!
    On another note last week I also had some goodies arrive from Tim @ dubaddiction
    juicy!
    ---------- Post added 21-05-2012 at 04:48 PM ---------- Previous post was 20-05-2012 at 11:43 PM ----------
    More shtuff ordered today...
    - New Tie-rods Left and Right
    - New Rack Ends Left and Right
    - New Ball Joints Left and Right
    - New Wheel Bearings Front and Rear
    - New Discs for the Rear
    The A-Arms already have some Polyurethane goodness installed in them...
    - 2010 Golf R
    - 1997 Golf VR6
