wow, great passat mate. love the wheels too (I have them on my cabriolet![]()
PS - i have a passat diesel radiator if you have need of better cooling.
Ok. So now that this 2L 8v engine conversion has the go ahead I thought I would do a proper, dedicated restoration/conversion thread.
Car is a 1976 Passat LS. Bought 3 years ago for a cool $1000 with 290,xxx on the clock. Had a heart transplant to a golf 1.6L engine 6 years ago. Im the 3rd owner, previous owner owned it for 31 years. Local tassie car.
Im my time of owning it I have done a few things:
-New headlights
-Fresh speedo
-Front wheel bearings
-Upholstered door cards
-Upholstered dash in black suede
-New shift linkage bushes
-Healthy drop
-BMW BBS Basket weaves 14x6.5 wrapped in Falken ZE912 185/55R14
-Twin 40 webers with Pipercross sock filters
-Basic two speaker stereo
-Edead sound deadening
-Redyed original carpet
Now Im starting the conversion to a mk3 2L 8v. After ordering needed parts for the conversion from techtonics, weberperfromance.com.au and other various sites the fun will begin in the following weeks.
Heres a few picks of how it was to how it is now
How it was when purchased.
And how it sits today
---------- Post added at 12:45 PM ---------- Previous post was at 12:43 PM ----------
Im trying to sort out what kind of jets I need to run the 2.0 engine while staying with the 40's rather than going 45's.
Pulled the current jets out to see what size they are for curiosity reasons, knowing that no matter what size they are they will most likely have to be change.
Ok heres the current setup.
40 DCOE weber
Primary Venturi/ckoke - 28mm
Primary Main Jet - 115
Primary Air Correction Jet - 160
Primary Emulsion Tube - F47
Idle Jet - 59 F21
Clearly these webers had been set up for quite a smaller engine.
This is the jet route in thinking of taking with a 276 cam
Venturi/choke - 36mm
Primary Main Jet - 145
Primary Air Correction Jet - around 190
Primary Emulsion Tune - F16 - F12
Idle Jet - 50/55f9
2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
1986 SAAB 900 Turbo 16 S
'98 Mk3 Cabriolet 2.0 8V
'99 A4 Quattro 1.8T
Siiiick!!!!
Nice one man
the above gentleman is a TDI Guru if u eva want to do that hehe
Hows the door trim i love it!
cant believe its looking so good
all that fresh green grass in the pic is makeing me miss ol Tas
so can u put up a short vid of this doing a dirty little burnout i mean all the mk1 era cars on here are FWD
would be a bit a funi know youv tried it?!
Way cool.
Subscribed.
No doubt I will play with a TDI conversion but it wont be with the B1. Certainly is green down here along the coast
Gldgti, mate your timing couldn't of been more perfect. My radiator is leaking slightly from the top tank and it has just about had it. Is the diesel one bigger? Regardless I will PM you
Still have plans for the brakes, the suspension, the body work and the interior still needs a finishing up. But at least the wheels are done hahaha
---------- Post added 06-12-2011 at 09:15 PM ---------- Previous post was 05-12-2011 at 06:02 PM ----------
little order came today from weber performance.
Lynx soft mount kit
36mm venturies
Carter electric fuel pump P4070. 4-6 PSI
Parts are starting to collect up.
3 Speco gauges and an Autotech adjustable cam gear From Chris at TPR Engineering.
Also scored a duckbill from Dan which I had to trim slightly to fit the Passat. Photos of it are taken just after fitment. So there still needs to be a bit of tidying up to do. Got my eye on some aftermarket indicators as well. Number plate is bugging me so I will get a slim line version for the front. But you get the idea
Nice score its really neat!! I'm jealous. Thats a rare car now and rarer in that condition!
I prefer it with bumpers and without the duckbill though...
Are you gonna do anything with the E30 wheels (colour??)
Whare abouts in tas are ya?
Thanks dude
i plan to pu tthe bumper back on but at the moment it will obstruct the number plate and I dont really want to be pulled over buy the police. A slim line number plate will fix that
I was thinking of changing the colour of the basketweaves but I have grown fond of the original look of the wheels.
Im in Devonport
I received my 2.0L ADY engine and spare B1 passat gearbox late last week![]()
Had some spare time at work today so took the head off for a general inspection then took it home where lives on an engine stand while the work begins.
I was actually surprised at the condition of the head and the bores etc....Supposedly this engine has covered a fair amount of k's. The piston tops have very low carbon built up. The water jackets in the head and block arnt too bad at all and the bores still have honed markings on them.
Current plans are to strip the block, inspect the pistons, bearings, rings etc and then take the block and pistons to our local engine re-builder so he can measure the bores and pistons and tell me if I need to go over-sized or just new rings
While the engine was a work I fitted a welsh plug to one of the crankcase breather holes and will make up a plate for the other hole just bellow the engine number.
How many KM's has the engine done? Looks good to me!
