36mm is a big choke in a 40 DCOE. It may not be pleasant to drive. I wouldnt go past 34mm. But with a big cam it may not behave below 3500rpm anyway
supposedly around 400,000 mate.
2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
1986 SAAB 900 Turbo 16 S
Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
Change of plans with the head. Had a bit of drama so decided to run it standard with the addition of a techtonics tuning 260 cam and ported and polished exhaust ports.
Still a little to go. More clean up of wiring, sort out coolant hoses and other maintenance stuff.
Looks really nice, wonder what the difference in performance will be like.
-'75 Passat TS
-'75 Passat TS (Project)
No....its not a Piss-sat its a Pass-sat!!
looks great!
old school cool! Love the clear dizzy cap
Very nice. You're as bad as me.. Fitting the carbies and taking pics before you even have cams (or A cam in your case) in it.. Haha
Haha. The carbs are a mock fit so I could work out the linkage setup
Does the mallory ignition require a crank angle input? Is it easytoset up ?
