thank you It really really wasnt supposed to go anywhere near this. It just kinda generated momentum and the more I used it I loved it but knew I wanted more from my jetta
fitted the sebrings
then some 15" P's with 165 bridgestone's
spends most of its life in the air lol
fitted the(jetta's)seam welded wishbones,poly bushes and powdered strut brace
and more recently have had it off the road while I tool about in my mark 2 as I collect a store of bits. Found oem lhasa green front wings,a set of oem plastic arches as one of mine had parted company although im looking into berg arches or at least a clipper kit,currently having the(jettta's)seam welded and powdered)rear beam fitted with polo stub pins and rear drums,a bigger master cylinder and new in-tank lift pump and external main fuel pump and possibly the(jetta's)powdercoated eibach ARB's ive had lying about along with (the jetta's)fk konigsports with a view to getting it track ready for next years track day sessions and ive been promising myself a nurburgring trip for ever and 180na horses should be quite fun round a track.
as it reads ive pretty much just robbed my jetta off everything but after deciding to go 16vT with the jetta and fitting the early part of the un-needed stuff from the jetta I had a rethink as the golf is now hardly a day to day car,its very harsh already,the engine even just as an NA(fully polybushed)has your teeeth rattling from the initial key turn and not what I want from my jetta which is why ive stole so much from its parts bin as I intend vr'ing it so much of it is redundant(strut brace will catch on the planned install,seats are not comfy on a long run[over 5 hours is a definate no-no]the good bits off this engine would need changed going to a 16vT anyway so that would have been a waste as well and pretty much more excuses in the same vein :p
