Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Money or the box...
    Perth. WA
    well into the accumulation phase at present, many boxes arrived from Germany, UK and the US with still more stuff coming...
    Been spending time on Anton's Mk1 clone, now with a built 2E lurking in the engine bay.
    pretty well rewired the whole car back to VW spec ( colour code, wiring size, connectors etc ) building reliability into the car..
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
    Mar 2010
    Perth
    Yip Thats right! Once we started we couldnt really let some of the stuff go! Will be posting a thread soon about the build. Will be good to see the Rocco project in full swing!
    1976 Mk1 LS 2L ABA K-Jet
    Perth. WA
    Easter break and finally some time to get things Roccin '
    Shuffled some of the stuff about in the shed and set to work..
    took a bit of effort to remove the guards without damage..
    But all came away intact.
    Main reason to remove and replace guards is to ensure this weak point of Mk1 construction is protected against rust.
    Requires a good coat of paint at the A pillar junction to ensure integrity.( top and bottom )
    Inner guards and inside the guards themselves will be getting a coat of 2 pac before reassembly.
    There's a few minor holes/ cracks to weld closed.
    Need to close up the hole to once again fit a O2O rodchange mechanism.
    More as time permits .
    Cheers,
    Grant...
    Perth. WA
    Another easter fast approaching !!
    Only been nibbling at the edges of this project as time is a bit of a rare comodity at present.
    However....
    Managed some more stuff from VW Classic parts
    Cleaned up a lot of bits ( dip, blast, electroplate, painting still to be done )
    Trial fitted a factory A/C console ( only available for left hand drive vehicles from the factory as per golf Mk1 )
    And salvaged some tinwork from older cars to replace the parts removed for the 1.8T that use to live in here...
    Loads more to come back from the platers & overseas, just free time would be a blessing...
    Cheers,
    Grant...
    Dec 2007
    Perth, WA. *YAWN*...
    Nice going bingley!
    I dropped into the shed saturday morning on my way home from the mk2's emissions test but you weren't there obviously. Hope to catchya soon bud!
    Perth. WA
    Was home doing the housework....
    Val is in Bangkok, I'm away later this week. shoulda txt me man.
    Cheers,
    Grant...
    Perth. WA
    Not much movement other than deburring and refurbing component parts...
    Managed to get some more NOS stuff for the Silver green Scirocco also...
    Currently doing an 020 rebuild / update for Anton's Mk1 golf ( Wavetrac coming ) so been making a few tools..
    Cheers,
    Grant...
    Mar 2010
    Perth
    Looking good Grant, you've really done nice job on the tools for the gearbox rebuild! The rocco needs to get rocking too!
