MK3 VR6 Brake upgrades
After reading how simple an upgrade the 312mm TT upgrade is on a MK4, i was wondering what would be involved in the same upgrade on a VR6.
As i already have the 288mm disks and calipers, would i only need the carriers, and disks?
Is there a better upgrade for similar money?
what would be the differance between these (TT) and VR6 brakes with better pads and slotted rotors?
will the 312mm fit in a 15" rim?
Don't know if the 312s fit a mk3 but you would defo need 16s. I have them on my A3.
u need to space out the caliper a little bit too. ecs tuning sell a spacer kit with longer bolts
minimum 16" rim. depending on the design not all 16s will fit tho
I am running 312mm in 16s with about 2mm to spear.
- You may not post replies
- You may not edit your posts
Forum Rules
