Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Mk3 8v Crossflow
    Aug 2006
    Melbourne VIC
    Mk3 8v Crossflow
    Hi gang,
    For a while iv been wanting to build up a cross flow engine for my Mk3. Build up something cheap with ebay specials and what ever I can get for free. Labour is noting and it will be a good learning experience.
    Iv broken it up into 4 catergories:
    Head
    Use a newer head from a Mk4 or new new bettle.
    Do I go ABA or AEG
    Bottom End
    ADY or AGG (I don think there is any difference
    Induction
    Thinking of using the iduction from a Mk4/new bettle but it would be nice to get a manifold etc from a US aba.
    Maybe ITB's of some form
    ECU
    Well this is where im still unsure.
    Do I use a modified 2e a ABA/AEG or stand alone.
    Id like to keep costs down but think ill run into trouble with OEM stuff, only problem being stand alone will cost $$$ which would be better put towards a 1.8t conversion.
    And the question is does a cross flow head fit on a Mk3 2ltr bottom end?
    Camden, Sydney
    I want someone to do this.
    I have the following info.
    Late model 1.6 and 2L crossflow engines are different critters to the early ones, but the heads are virtually the same. I did once hold a 2L Golf 3 headgasket on a Mk4 1,6 head and it nearly fitted. I think a couple of oil holes needed to be enlarged in the gasket.
    ABA bottom end is nearly the same as a 9A, it has oil squirters in the bottom and different pistons to the other 8vs. Thats why the Yanks love them with a KR head and hey presto their own homegrown ABF!
    I have an ABA engine tucked away and it has the fuel rail and intake. I theorise that you could run it on digi.
    Twist my arm and I might part with it.
    I have also seen a latemodel Cordoba 1999 with a crossflow engine, it is a 1.6L and made more power than a stock 2L apparently. A lighter car and 2L bottom end and it would be a screamer.
    AEB is 20VT from an Audi A4 mate, like I have in the rocco. Would be work to make it NA. The ADR engine is the 1.8L non turbo Audi derivative.
    I have a couple of 1.6 heads at the shop, I`ll try and mate up a 2L 8v head gasket tomorrow and see what it looks like.
    I reckon you could fuel that with your ecu and slap the head on your bottom end, keeps the numbers right and the RTA happy.
    Aug 2006
    Melbourne VIC
    So loon your saying a Mk4 1.6ltr is a cross flow head?
    Remember my car is a CL so 1.8ltr monotronic (Single point injection)
    Camden, Sydney
    Yup, Golf 4 is crossflow.
    Block is definately different, Mk4 has internal waterpump, cant find a head here at the shop.
    Singlepoint might not be enough to fuel it.
    Aug 2006
    Melbourne VIC
    Yeah I have a complete bottom end from a New bettle and when I pulled to the sump of to have a look (AhhhhhI might put that back on thanks...)
    Sep 2006
    West Sydney
    I haven't got much to tell you but I've been looking into it a bit to see what stuff in the US can work on our (my) U-flow 2.0L 8V.
    The US Mk4 2.0L 8V has an AEG code (I'm guessing that's what you meant in your OP, not AEB) while we had the AQY/APK/AZH. I haven't seen any builds running an ABA bottom-end w/ AEG head so I assume there's 1) not much difference or 2) doesn't fit. From what Matt has posted, I'm guessing #1 would be the correct answer. However a common mod is to run the AEG intake manifold on the ABA as it has larger ports and runners. There are a few DIY articles on Vortex so hit it up for what you might need there. The AEG intake manifold I believe is the same as the intake manifolds we have on our Mk4 2.0L 8V. Part number is: 06A 133 203 AA for AEG; 06A 133 203 H for AQY/APK; 06A 133 203 AM for AZH. I don't know what the letters at the end of the part numbers mean though, but hey, the numbers are the same!
    ELSAWIN's not working on my new computer but I'll try installing it on my sister's laptop and check the specs between ADY and AGG to see if there's much of a difference. I do remember being able to compare between engine codes. At the moment, all I know is, Aussie-delivered Mk3 2.0L were 2E for the very early ones, ADY from late '94 to early '96, and AGG were fitted after that (could be wrong).
    Valvetrain parts between the ADY and ABA are the same - the OBDI ABA and early ADY engines (engine numbers upto 000 778 ) use the dual valve-spring setup, whereas the OBDII and later ADY engines (000 779+) use single valve-springs. I've cross-referenced the part numbers and they are identical. That said, the engines with single valve-springs can be converted to dual valve-springs as long as the spring retainers (lower and upper) from the dual valve-spring setup are used. Intake and exhaust valves I'm not sure, I didn't check them. Hydraulic lifters are interchangeable between all 2.0L 8V, including Mk4s. The thing is, the Mk4 ones are lighter (by 15g each), so I think better performance can be had by using them (part number 050 109 309 J). I don't know what the implications are relating to wear, but from what I've read and asked about, as long as the components are used in their original place (inlet valve for cylinder 1, exhaust valve for cylinder 1 etc.) then it should be fine (obviously this only applies if you're reusing these parts). Standard camshafts have different part numbers between ADY and ABA, but they're interchangeable (many UK owners have upgraded to camshafts imported from the US and they work fine).
    Just FYI, the part numbers were pulled out from ETKA version 7.2.
    Aug 2006
    Melbourne VIC
    Yeah AEG sorry.
    So can I whack a Mk4 cross flow head onto a Mk3 2e block?
    Aug 2006
    Melbourne VIC
    And AQY/APK/AZH are all 2ltr cross flows from Mk4, New bettle or bora?
    Sep 2006
    West Sydney
    They use the same intake manifold so I'm going to say yes.
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by rayray086 View Post
    Thats interesting that a non-cross flow head has the same inlet bolt up pattern as a cross flow head.
    I think there is only one way for me to find out get a 2e bottom end a crossflow head and whack the 2 togther.
