Results 1 to 10 of 10
Thread: mk2 golf 20VT megasquirt converion
    Aug 2009
    waikiki, WA
    After lengthly discussions on this forum and much research on the options available to raise the performance of my MK2 8v Digifant GTI Golf. I have decided to ditch the 8v unit and replace it with an AGU 20v Turbo unit from a golf GTI MK4. The hard part as most of you know is the wiring! I am determined to not go to www.qpeng.com and part with 1000 pounds sterling for a plug and play kit. I want to use Megasquirt!
    I know from my own research others have done this conversion and have left some info on how to wire this particular install. But it doesn't look like enough to get thing rolling! I guess what i need is an idiot proof installation guide with a few pictures. Plus an all important wiring diagram.... Any help on this greatly appreciated.
    Feel free to send me an e-mail on cfisher85@hotmail.com
    Jun 2007
    Eastern Suburbs Melbourne
    I'm guessing you've look on the MS site... it's pretty much got all the info you'll need to set it up. I'd suggest reading everything twice before you get stuck in
    http://www.bgsoflex.com/megasquirt.html
    http://www.megamanual.com/index.html
    http://www.megamanual.com/mtabcon.htm
    start from those links and get reading!
    i like volkswagens
    Camden, Sydney
    Talk to pepperwhite on here. He just setup his Mk1 16v with Megasquirt, with no prior experience of it.
    The QPeng is already chipped so that would be a plug and play 190+hp. The hassle involved in doing megasquirt will be considerable. Not saying you won't know lots about it all when you are done but the time involved in tuning it will be massive.
    I have everything to get an AGU running if you change your mind.
    Good luck with it though.
    Aug 2009
    waikiki, WA
    Hi Gavin,
    When you say you have everything to get an AGU running. Exactly what setup are you talking about?
    Quote Originally Posted by pommydubber View Post
    Hi Gavin,
    I scrapped an 1998 A3 1.8T and have the loom, ECU, clocks, key reader etc.
    Aug 2009
    waikiki, WA
    Hmmmm, A few questions i have for you....
    What engine code is this unit?
    Will it bolt into my 8v GTI MK2 and mate up to my g/box ok?
    How many k's has it done?
    Is it in good condition?
    If you are selling it how much do you want for it?
    The engine isn't complete, I sold a few bits off it. So it wouldn't be a full conversion.
    I thought you already had an engine but nothing to run it?? Mine is an AGU but I would suggest you find a complete one as buying the bits one at a time would be tiresome and not real cheap.
    I would do the loom and clocks etc for $500 and if you wanted it chipping, I'd sort you out once you get it running.
    Dec 2008
    Just a side note, I got to meet Gavin when he was up in brisbane a few months ago. Nothing but praise for the guy! You'll be in safe hands.
    Jun 2006
    Hornsby
    buy a haynes manual for the wiring on the AGU.
    the qpeng is good, I run mine and its sweet as, might be a tad exexy but think of the money you will spend on the Dyno to get the MS tuned, it aint cheap plus my 28rs map will only cost me 100 buks rather than 400 or so to get it mapped on a DYNO.
    And i have to say IMO the wiring is the easiest part of this build (cooling systems was a bitch to work out). The AGU is not just a staight swap you will have to move a few things around, PM me for details if you want.
