cheers fella, i was looking to go HID...so will do the replays first
Heres the diagram i followed and got great results.
You can also use 4 relays instead of 2 realys. One pair of relays for driving lights and the other pair for the high beams, regardless if you have a double or single light grill set up.
This pic might also help:
If you are going to install a HID kit in to you mk1 or mk2 you MUST do the upgrade.
I've also done the upgrade with great results on light output and voltage.
For the 2 relay upgrade will all the wires and fuze holder it will cost about $20-25 for Jaycar and 4 realy upgrade is aditional ~$10.
MK1 GLS 3door
A4 B7 2.0T
just did that first, simpler upgrade from the first page, seems to have worked so far. Just need to wait till it's night really.
villy_16V, did you actually measure the relay terminal 87 output voltage ? do you get 13.7V ?
I've done this 'upgrade' last month, I still only get 12.?V in terminal 87 but I feel the headlight is brighter
Parts for sale http://www.vwwatercooled.com.au/foru...ff-102387.html
Just saw this gold!
I'll do this when the front's off for the conversion.
If only I knew this on that dark fateful night i killed my old Mk2, I might've seen the bloody t-junction sooner
Just did this today!!!
Can't wait to see the results a night
Thanks
So to confirm, this will make a difference even though I have a 90 spec GTI?
