Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: mk1 and mk2 Headlamp Wiring upgrade...this is a MUST!
    Feb 2007
    Heres the diagram i followed and got great results.
    You can also use 4 relays instead of 2 realys. One pair of relays for driving lights and the other pair for the high beams, regardless if you have a double or single light grill set up.
    This pic might also help:
    If you are going to install a HID kit in to you mk1 or mk2 you MUST do the upgrade.
    I've also done the upgrade with great results on light output and voltage.
    For the 2 relay upgrade will all the wires and fuze holder it will cost about $20-25 for Jaycar and 4 realy upgrade is aditional ~$10.
    MK1 GLS 3door
    A4 B7 2.0T
    cheers fella, i was looking to go HID...so will do the replays first
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    Jun 2007
    Eastern Suburbs Melbourne
    just did that first, simpler upgrade from the first page, seems to have worked so far. Just need to wait till it's night really.
    i like volkswagens
    villy_16V, did you actually measure the relay terminal 87 output voltage ? do you get 13.7V ?
    I've done this 'upgrade' last month, I still only get 12.?V in terminal 87 but I feel the headlight is brighter
    Quote Originally Posted by RedMk2Gti View Post
    the write up is from a post off clubgti years ago...i didnt take the readings sorry....but if they are brighter...who cares lol
    Velly
    '91 2.0 8v GTI
    Dec 2007
    Perth, WA. *YAWN*...
    Just saw this gold!
    I'll do this when the front's off for the conversion.
    If only I knew this on that dark fateful night i killed my old Mk2, I might've seen the bloody t-junction sooner
    May 2010
    NQ
    Just did this today!!!
    Can't wait to see the results a night
    Thanks
    Apr 2008
    So to confirm, this will make a difference even though I have a 90 spec GTI?
    May 2010
    NQ
    Quote Originally Posted by benough View Post
    Mines a 92 and my low beam lights are acuatlly white now!!!! Not that dull yellow
    Took me 2 hours tops.
    Its just like running spot lights, pretty dam simple too, cost me $35 all up.
    A relay kit and a new pair of headlights make a massive difference. If the lights are the original ones, they'll be covered in little stone chips that scatter the light. New ones are so much better.
