Results 1 to 10 of 20
Thread: mk1 and mk2 Headlamp Wiring upgrade...this is a MUST!
    W3LSH’s how to on uprated headlight loom
    I thought it was about time I uprated the headlight loom on my mk2 golf again after changing my original cars loom from pre 90spec to 90spec with the g60 conversion.
    I’ve take some pics along the way to make a ‘simple how to’ for anyone who may want to do the same
    The difference is incredible too
    Parts needed
    1. A Relay with 30-amp switching capacity
    2. 20-amp fuse
    3. Quality fuse holder
    4. Blade connectors, blue & yellow type
    5. Ring connectors to connect to the battery
    6. Suitable cable
    Total cost? Under a tenner (uk money)
    To start with you need to find the wire that provides the input voltage to the lights
    I then cut this wire to have the required input and output for the relay
    spade connecters were then added
    I quickly measured out the cable I would need to go from the battery (+ve and –ve) along a hidden route on top of my intercooler so the loom would not be visible
    The two battery ring connecters, fuse holder, and relays were added
    After the wiring was put in place, all I had to do was connect the two connectors I had cut earlier to the relay
    Here’s a simple pin diagram of this
    By running the wires across the top of the intercooler (or rad) the loom is also not on display - but gives a different result to standard
    Hope some people find this useful
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
    here is a text way of going it, you really shopuld get the picture by now!
    Vel
    Headlamp High Powered Loom !
    This mod is DEFINITELY REQUIRED.
    Why?
    Because if you get your voltmeters out and just check the voltage
    on the standard headlight connectors.
    Main headlight is 12.5V and high beam is only 10.2V !!!
    A pure voltage drop!!!!! I knew there was a voltage drop but not THAT much !
    The standard loom is poor.
    I don't know if it was just my car or all VW's, because of this, not even
    your standard bulbs are being lit up to the max.
    You're losing about 8W of power on full beam PER BULB !
    With the mod, you get a full 13.7V for both main and high beam !
    So even your standard bulbs will be brighter.
    Another advantage is the power is taken direct from battery, the rest of the
    cars electric's have less strain so they have more power.
    - electric windows, bass on full etc etc.
    Its been safely tested for couple of years on long motorway journeys.
    At first I was a bit dubious as to whether the system would heat up.
    But not even warm!
    The standard loom gets warm but this was freezing even after 5 hours
    continuous use!
    Thats why best to use 30 Amp gear rather than 20 Amp which BRM (should I say
    that) provide.
    Dead easy to do:
    Kit
    30A Wiring (6 meters) - 4 quid
    Battery connectors - 3 quid
    30A Fused relays * 2 - 3.5 each
    (Get these so you don't have to buy inline fuse holders)
    2 headlight connecters from scrappies (Off any big Audi or BMW cos
    they're 30 Amp standard)
    Thats it !
    This kit is rated for up to 180W main beam and 180W high beam bulbs.
    Giving a total of 720W lighting power!
    (Standard is just 60/55*2 = 220W - Voltage drop = 204W)
    I've got 100/80W bulbs. Any more and you might get pulled so best not
    to go over 100, or 120W maximum.
    Wiring is a piece of cake.
    Just got to be careful how you wire the relay up.
    Looking at the relay pins
    Pin 30 - common goes to the battery +
    Pin 84 - open feed, switch which will go to the connectors
    Pin 85 and 86 power this will be taken from the original headlamp
    connector.
    NOTE : Don't cut your original headlamp connectors !
    Headlamp connector wires
    Looking and starting from the left standing in front of the car the top of
    the reversed T shape has yellow (low beam) and if you remove the plug from
    the lamp and look at it with the wires facing you the right has white (high
    beam) and the left has brown (negative).
    Relay one (High beam)
    Pin 30 goes to the battery
    Pin 84 goes to the white wire on the new connector (the one you've got from
    the breakers) Don't forget you've got to parallel it for the otherside.
    Pin 85 goes to the original connector white wire (I used the passenger side
    headlamp connector, nearest to the wire.
    Pin 86 goes to the original connector brown wire (I used the passenger side
    headlamp connector also.
    Relay two (low beam)
    Pin 84 goes to the yellow wire on the new connector (the one you've got
    from the breakers) Don't forget you've got to parallel it for the
    otherside.
    Pin 85 goes to the original connector yellow wire (I used the passenger
    side headlamp connector.
    headlamp connector.
    The only wire missing from the (breakers) connector is the brown, just
    take the feed from negative terminal.
    1
    Velly
    '91 2.0 8v GTI
    good write up, a great mod to do. it was even worse on old beetles lol . but the mk1+2 can deff do with the upgrade. and thats how easy it is to run another set of spoties too.
    cheers brenton
    MK1 4door
    MK2VR6
    MK3VR6
    Transporter
    and untold wrecks
    rs.led Guest
    Found this on addition appointment - achievement it helps. It ability able-bodied boldness the aqueous headlight bung botheration and, because the headlight ability is beeline from the battery, will ensure best ability goes to the lights.the base diagram aloft is for a all-encompassing headlight base approach up brand and will plan for both absolute and abrogating switched headlight systems.
    If the new approach is fabricated to the diagram’s set up and access fabricated to the vehicle’s absolute headlight sockets, again there will be no charge to cut into or adapt the vehicle’s base in any way.
    Once the new approach is installed, the cars headlight globes will now be absolute about-face no amount what polarity the vehicle’s headlight about-face plan by.
    The acumen for application 4 individual pole relays instead of 2 bifold poled headlight broadcast is to access safety. If accepted bifold poled headlight relays are acclimated and a agglutinate assault or a broadcast fails, you can apart either both low axle or both top axle at the aforementioned time.
    BY:
    LED Flashlight
    Penrith, NSW
    I have no idea what that guy just said.
    1986 MkII Golf GTI 16V (Sold), 2005 MkV Golf GTI (Sold), 2007 Polo GTI (Sold), 2011 Polo 66TDI (Selling), 2012 Passat 125 TDI Bluemotion, 2013 Scirocco R (Due October!)
    Boronia VIC
    Quote Originally Posted by anarchycamp View Post
    That's because he's a spammer. The diagram is actually plausible though and the text is just so funny that I'm inclined to leave it there.
    I've removed the link to his website to comply with our advertising rules and for everyone's safety.
    Pete
    Sep 2008
    Fitzroy, Melbourne
    Nice one Pete.
    .. that text was so bad I think it gave me cancer
    76' 2dr Kjet
    and those the haters
    Pictures of the differences:
    Normal Dipped
    With Loom Dipped
    Normal Hi-Beams
    With Loom Hi-Beams
    be safe....be seen!
    Velly
    '91 2.0 8v GTI
    Jun 2007
    Eastern Suburbs Melbourne
    Will the upgrade shown in the first post, just upgrade the low beam, or the high beam lights as well?
    I'm planning on doing this mod tomorrow, all being well.
    i like volkswagens
    i think my one just does low beam....but the diagram posted below will do both (i am sure mr jones will correct me if i am wrong lol)
    Velly
    '91 2.0 8v GTI
