Results 1 to 10 of 18
Thread: Mk1 GTI brake conversion
    Apr 2006
    Melbourne, Victoria
    Hello everyone,
    whats required for the Mk1 GTI brake conversion??? All the bits are going onto a Mk1 Diesel that has the squareish pads and thin discs. Dunno about caliper bolt spacing.
    For the GTI conversion, I've heard mention of hubs, discs and pads being different but the caliper being the same as the petrol golf. Is this correct?
    Also, where can I buy the GTI discs? Are they available new in australia?
    Where can i get the hubs? What model petrol golf has the right calipers?
    Or am I better off going to pickapart and grabbing bits off a camira/commonhore? Has anyone done the Camira conversion? It appeals as the camira discs are 4x100.
    Also, what the hell is a G60?
    Soo many questions......
    Cheers,
    Matt
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Camden, Sydney
    If you are gonna change to GTI setup, you need the hub assy, different calipers, rotors, and bottom balljoints and wishbones.
    Camira setup is ok, as you can kep your hubs and get all the bits easily and cheaply, but you will need to modify or shim some parts, which may not be 100% legal, although who is gonna check that on an old Mk1?
    Camden, Sydney
    Jun 2007
    Eastern Suburbs Melbourne
    I havn't had to change hubs ball joints and wish bones. I previously had GTI brakes on my petrol 76er & have recently installed them on my 79 Diesel.
    I used a complete GTI set up ie, discs & calipers [and pads], and took the standard discs and calipers off and put the GTI caliper and disc straight on. didn't need to change hubs or ball joints...
    i like volkswagens
    Camden, Sydney
    How does the caliper fit onto the early hub mate? The mounting holes are different.
    Sounds like your diesel already had later brakes on with a solid rotor, which you can change to vented ones with different calipers.
    I dont believe you can swop from standard early mk1 brakes to GTI ones and retain the original hubs.
    Pics would help as usual.
    Jun 2007
    Well they did Matt. Let me have a look through my build thread on teh 76er, I reckon I would have taken a pic or two.
    http://www.vwwatercooled.org.au/newf...?t=7334&page=5
    i like volkswagens
    Camden, Sydney
    Here is the pic Jarrad. Did you just change the rotors? Or calipers too?
    Watch those poxy little bleed nipples, I have lost count of the number of those I have snapped off in my time. All rusted in solid.
    I got into the habit of heating and allowing them to cool a few times before attempting to undo with a socket not a spanner.
    Camden, Sydney
    Had a look at all the brake setups at the shop today. and it would appear that Jarrad is right!!!!!!!!!
    The original Mk1 hubs have the correct bolt hole spacing for a Mk2 caliper and rotor.
    We all learn something new every day.
    I have 2 rotors and one caliper, for anyone looking for a set. And 2 hubs if anyone needs.
