Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Mk1 GTI brake conversion
    Jun 2007
    Eastern Suburbs Melbourne
    Here is the pic Jarred. Did you just change the rotors? Or calipers too?
    Rotors and calipers, as I said in an earlier post
    Mk 2 GTI calipers fit straight on as well? I didn't know that. I assume then that mk 2 hubs must be the same, or very similar to late mk 1 hubs. [the difference on the mk 1 hubs being the smaller ball joints on earlier models]
    i like volkswagens
    Camden, Sydney
    Mk2 has a completely different hub setup, These can be removed and replaced with Mk3 hubs and brakes.
    Mk2 hubs do not fit a Mk1 as the offset and camber is different.
    However, Mk1 GTI calipers and rotors are the same as Mk2, so that is the source for them in Oz.
    I got filthy pulling out untold hubs and measuring stuff for you lot, I hope you are all grateful
    Apr 2006
    Melbourne, Victoria
    Always grateful Matt,
    The GTi discs and caliper you sent fit fine on the Mk1 diesel!
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
    Apr 2006
    Melbourne, Victoria
    I've heard mention of Mk1 GTI calipers being the same as certain Mk1 petrol calipers, the difference in disc thickness being accommodated by thinner pads. What Mk1's had the same calipers as the GTI's? I need a driver side caliper to complete my vented brake upgrade.
    Matt
    Apr 2006
    Melbourne, Victoria
    Here is the pic Jarrad. Did you just change the rotors? Or calipers too?
    I have the same caliper as Jarrads, well a passenger side one anyway. Does anyone know where i could get a driver side caliper? Are these fitted to any other european cars? The caliper is are made by ATE. Also, where to get pads???
    Thanks guys!
    Boronia VIC
    Quote Originally Posted by hiho View Post
    Not quite right there.
    239mm 10mm thick solid disc (Diesel Std) use pad DB-128 18mm thick
    239mm 12mm thick solid disc (Petrol Std) use Pad DB-105 14.8mm thick
    239mm 20mm thick vented disc (GTI Std) use pad DB-242 15.3mm inner & 17.3 outer
    256mm 22mm vented disc (16v Scirocco) use pad DB411 15.8mm thick.
    Caveat: I pulled this info from the Bendix catalog which isn't always right.
    Diesel and Petrol Calipers can be the same with different pads to accomodate for disc thickness.
    There's also a DB-145 listed for Petrol Golf but I've never seen this one in the wild
    Sometimes the DB-128s don't work on the diesel discs, if in doubt the DB-105s are the safe bet, they'll work in either.
    Audi 80 Calipers from 1978 - 1990 use pad DB-401 and bolt up to the MK hubs and work with the 239mm vented 20mm thick GTI discs.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Apr 2006
    Melbourne, Victoria
    I think this caliper is off a mk2 gti. Loon, can you confirm?
    Sep 2009
    Chillaxing in Tas
    I swapped my fronts to GTi vented rotors yesturday. and it all just bolted up.
    All i had to do was bend and hammer the backing plate as the caliper fouled on it. would have cut it, but didnt have the grinder here.
    Havnt driven it yet as car ha sno engine
    <space for rent>
