Page 14 of 16 FirstFirst ... 41213141516 LastLast
Results 131 to 140 of 157
Thread: The Mk1 ABF Project
  1. #131
    Dec 2009
    Fitzroy, VIC
    Just answered a PM about freight charges etc., thought it beneficial to post it here:
    In response to 'how much did it cost to import the engine?':
    Quote Originally Posted by cartertronic
    "It's difficult to say, as I shipped a 2m x 3m crate with heaps of other stuff inside:
    -1997 Mk3 GTI (bought whole car) = 461 GBP
    -Towing = 165 GBP
    -Crate = 240 GBP
    -Shipping = 440 GBP
    -Customs/Local Freight Handling Fees = $830AU (incl. fumigation charges)
    In all honesty, if I had to buy another ABF I would source it locally! Unless you need to bring in a whole lot of other bits and pieces, it'll definitely end up costing you more in time and money... then there's the hassle of arranging it etc.
    Either that, or try to find someone with a container coming to Australia, that way you might be able to skip likely hassles with customs...
    A word on customs: After picking up my crate that had been literally torn apart by customs officers and reorganising all the items inside that had been piled back in the remains of the crate (damaging several items), I spoke to the freight handler..
    He said customs officers actively target small private crates as these are most common for amateur criminals bringing in illegal items/drugs etc. Apparently they also "high-fived" (he witnessed their inspection) when they found a bug, as this means they can charge fumigation fees."
    EDIT: Just looked at my original thread post where I said I was planning to keep it under $3000! If you just include the above the total is $2800... mission accomplished (if you exclude the bucket loads of cash I spent on other bits and pieces haha! )
  2. #132
    Dec 2009
    Fitzroy, VIC
    Couple of goodies arrived today
    VR6 Water Pump Pulley (for power steering and air conditioning delete - since getting a daily driver I've decide not to go down the track of installing AC)
    ..and Mk2 256mm Brake Discs (to go with the Calibra 16v calipers and carriers!)
  3. #133
    Perth. WA
    discs arrived all good mate
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  4. #134
    Dec 2009
    Fitzroy, VIC
    Quote Originally Posted by roccodingo View Post
    Thanks mate!
    ..also picked up rear disc setup from Dom today, now to find time to fit it all up!
  5. #135
    Dec 2009
    Fitzroy, VIC
    Was clearing space in the garage last night and noticed the rear mount bracket (bolted to the transmission) is broken.. not sure how that happened
    That flat piece that sticks out should have two holes for the rear engine mount bolts!
    (or perspective of where this bracket is located...
    These should be a dime a dozen, anyone got one lying around?
  6. #136
    Boronia VIC
    I've got one.
    I've had to weld these up in the past. Makes 'em stronger.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  7. #137
    Dec 2009
    Fitzroy, VIC
    Great tip!
    PM Sent..
  8. #138
    Perth. WA
    Yeah, seen a few cracked versions mate..
    Cheers,
    Grant...
  9. #139
    Dec 2009
    Fitzroy, VIC
    Had a bucks night over the weekend, but managed to make a bit of progress...
    Stripped down the front and rear calipers & gave them a good clean
    Rub a dub-dub, big brakes in the tub
    Sprayed red and hit with the heat gun, before baking in the oven for an hour.
    Lunch of champions (cooked prior to brakes)
    Fronts came out a treat. The clear coat gives them a great shine
    Rears being fitted
    Fitted poly bushes for rear beam mounts (with plenty of lithium grease to hopefully stop the squeaks)
    +Mk1 braided lines .. will have to track down some Mk3 braided lines for the other piece of flexi-hose
    Disconnected the old handbrake cables & brake lines, then dropped the old beam with sway bar and Cordoba drums.
    A few things to be done while the back is in the air, watch this space
  10. #140
    Dec 2009
    Fitzroy, VIC
    Bit more progress today..
    Fitted new rear engine mount bracket (thanks Pete!)
    Replaced the rear suspension. Out with the old, in with the new (+poly bushes)
    Simple job, but stoked to fit these!
    I know the world doesn't need another meme, but couldn't resist
    ---------- Post added 11-04-2012 at 01:53 PM ---------- Previous post was 10-04-2012 at 11:15 PM ----------
    Rang a few places about getting braided lines made (via www.braidedhoses.com.au - Thanks Pete), seems to be approx. $70-80 per line. Seeing as Mk3 Goodridge kits go for about $100 on ebay, might give custom lines a miss.
    One bloke I spoke to reckons buying pre-made brake lines from OS is a bad idea as they don't meet our safety standards!? Find this a bit hard to believe. Maybe no-name lines have suspect quality .. or maybe he's just trying to drum up some business
    Interested in making them myself, but could be asking for trouble:
    Making Braided Lines - Old Britts
    How to make braided brake lines - Custom Fighters
    How to make braided stainless steel brake lines - DoTheTon
    Teflon hose assembly - Earls Speed
