Page 13 of 16 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 157
Thread: The Mk1 ABF Project
  1. #121
    Mar 2011
    Bunvegas, Western Australia
    That looks heaps cool!!
  2. #122
    Dec 2009
    Fitzroy, VIC
    Quote Originally Posted by ByronRichesMk1 View Post
    Thanks mate! Although I don't think I'm going to bother putting them on now haha!
    Had a win at the wreckers today, when this flash of red caught my eye...
    It's a 1993 Calibra 2.0L 16v (nicknamed a 'redtop' for obvious reasons), which came standard with 256mm Girling brakes. Pretty rare in Australia, as I think we only got the 2.0L 8v and 2.5L V6 .. so must be an import.
    Was there to get a radiator hose for the ex-Mrs, so had to go back home for my full kit.. $60 is a bargain anyway you look at it
    These bolt straight up to Mk1 hubs, I'll just need Mk2 256mm discs and some shoulder bolts (12mm diameter x 25mm, thread is M10 to fit mk1 hubs). The Calibra flexi-lines also fit to the Mk1 brake line
    Or cut some 12mm pipe as sleeves..
    Should look like this once done (although I'm thinking blue )
    (these last 4 pics from The Mk1 Golf Owners Club.. see second link below)
    Hopefully they fit underneath my 15 inch Ronal R10s!
    For anyone interested, keep your eyes open for any of the following:
    1988 - 1995 Vectra 16v (GSI)
    1984 - 1990 Astra 16v
    1988 - 1997 Calibra 16v
    For more info see:
    The Mk1 Golf Owners Club - Vauxhall 256mm Front Brakes Part 1
    The Mk1 Golf Owners Club - Vauxhall 256mm Front Brakes Part 2
    VW Caddy Forum - Chavalier calipers
    VW Caddy Forum - 256mm brakes for everyone and cheap as chips
  3. #123
    nice score mate! I'll be keeping an eye out for them.
  4. #124
    Dec 2009
    Fitzroy, VIC
    Anyone got any recommendations about buying 256mm discs?
  5. #125
    Perth. WA
    Quote Originally Posted by cartertronic View Post
    Have them on the shelf here mate. PM me a mailing address and I can get you a price.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  6. #126
    Dec 2009
    Fitzroy, VIC
    Quote Originally Posted by roccodingo View Post
    Cheers mate, PM'd..
    Anyone have any experience whether it's worth bothering with drilled/grooved discs? I can't imagine 256mm discs will get hot enough to warp when stopping 850kgs of car
  7. #127
    Jul 2005
    Newcastle, NSW
    Overkill is endorsed. These are on the rear of my MK1
  8. #128
    Dec 2009
    Fitzroy, VIC
    Quote Originally Posted by mikinoz View Post
    They do look mean as hell
    What brand are they?
  9. #129
    Boronia VIC
    Depends what speed you're stopping from.
    I've got EBC dimpled and grooved 256mm discs on my white Golf. They get very hot with no issues so far.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  10. #130
    Dec 2009
    Fitzroy, VIC
    Hmmm...do want 'em, but bit low on cash
    In other news, picked up bolts, washers and loctite from Metro Bolts in Richmond.. looking forward to fitting it up!
    PS - Bloke recommended 222 to stop vibration, will this be strong enough and resistant to brake heat?
    EDIT - Found some info on http://au.iloctite.com/en/red-loctite-threadlocker
    "What is the thermal resistance requirement for the assembly? If the heat resistance in excess of 300°F (150°C) is needed, it is recommended that Loctite® 272 Threadlocker to be used."
    and then this..
    "High-temperature threadlocker Loctite® 272 can be used up to 232 ℃, If you want even higher thermal resistance , then the ultra high temperature products, such as Loctite ®2422 (medium strength) and Loctite ®2620 (high strength) which withstand continuous exposure to temperatures of up to 350C should be used."
    Found this technical data:
    Loctite 222 Technical Data PDF media.midwayusa.com/pdf/instructions/Loctite_222.pdf
    Paying attention to the heat strength and aging graphs
    So based on that, it drops to a minimum of 25% effectiveness when applied to calipers
    Loctite 272 Technical Data PDF www.reyher.de/download/Technical_data_sheet_Loctite_272.pdf
    Loctite 2422 Technical Data PDF
    65.213.72.112/tds5/docs/2422-EN.PDF
    Loctite 2620 Technical Data PDF
    65.213.72.112/tds5/docs/2620-EN.PDF
    Looks like 2422 improves at 350 degrees.. interested to know what happens after that!
    What do you guys use?
