Originally Posted by
cartertronic
Thanks lads! It's good to be back
Rocco - Have you done this before? From the looks of BrokeVW's site (
Opening the 020) it looks like I have to dismantle the entire thing to get to the diff??!
Re: testing bearing preload
I'm not sure if I've got the equipment/experience to get this done myself (and be sure of an accurate job) might be best to track someone down to install it.
PS - From what I've heard only 4spds and pre-1984 5spds need to be shimmed?
Pics are on the bottom of page 2 and some page 3..
http://www.vwwatercooled.org.au/foru...s-21212-2.html
And yes, all apart to take the diff out.
bearing preloads are explained in the bentley manual along with the part numbers for the shims. While your doing the diff , change the syncro's and any damaged gears etc.
I had to locate a torque meter to do the preloads on the new bearings, cost about $600 from some mtool mob in Adelaide, but then have done Wade's O2A since then and still a pile of others to do.
Lots of MK 1 Scirocco's...
Cheers,
Grant...
