I'm about to purchase all service/replacement parts for the engine conversion, I figure it'll be cheaper to get them sent over with the engine than bother later.
Thought I'd record it here to be thorough.
To be ordered from http://www.car-partsonline.com/MyPar...nd=ChooseModel EDIT - Company has gone bust due to factory fire :(
The list I have so far is:
-Timing Belt Kit (including tensioner) website (same company as above URL) says £19.00!?
-Replacement Waterpump £17.95
-Altenator / AC belt ?
-Mk2 8v GTI 210mm OE Spec Clutch Kit £55.95
-Ignition Lead Set £38.95
-4 x NGK Spark Plugs £3.30
-Fuel Filter £6.95
-VAG Oil Filter £2.80
-Inlet Manifold Gasket (upper and lower) £3.21 + £2.85
-Exhaust Manifold Gasket £4.70
-Sump Drain Plug & Seal £1.05 + £0.31
Never serviced a Mk3 engine so let me know if there is anything else I should be replacing..
