is that an engine mount to lower the motor?
i cant remember where i saw/read this, but does the bonnet of a golf 1 have the clearance for the 16v abf manifold? because it's a tallblock.
87' MK2 GTI
13' MK7 TDI
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
020 31kg
02a 38.5kg
02m 51kg
info from the net.not much weight difference and 020 could not handle any more power and 02a would be good up to 300hp stock.
custom mounts and cable+mechanism around $600
Actually the 02a is about 25% heavier if you do the maths. 7 or 8 kilos might not "seem" like much but it actually amounts for a fair bit.
ok i will take but what about benefits
is it worth $600
or if anyone know if there is any cheaper
finally started some work on the abf engine today. i remove the p/s pump,a/c compresor,alternator,belts and various brackets etc. in with the new alternator bracket for a test fit and find out that the original alternator can not be used with it. bracket is original vw for abf non a/c. does anyone know what alternator should i look for?
vagcat.com it to find out if the alternator is different. if u want an alternative u shoulda bought this a/c delete instead:
http://cgi.ebay.com/ebaymotors/95-96...Q5fAccessories
i bought one and sure its not 100% pretty but it spins straight and u can reuse everything that u already got.
i have find it! it is the following:
ABF - Non-A/C Mk3 setup
70 amp non-A/C alternator Spring tensioner
Bosch part number: AL0185X or 0-123-315-001
Worldwide Reman part number: 14356 (price as of 2/6/09 is $119.49)
VW part numbers: 028 903 025 G and 030 903 023 E
Valeo part numbers: 2541821 or 436363 or 439000 or A11VI66
Lucas (LOL) part number: A6785
90 amp non-A/C alternator
Bosch part number: AL0187X or 0-123-320-002
Worldwide Reman part number: 14358 (price as of 2/6/09 is $164.49)
VW part numbers: 028 903 025 P and 030 903 023 F
ACDelco part number: 321-1712
Lucas Part number: A6786
Valeo part numbers: 2541814 or 2541814A or 436443 or 439002 or A13VI123
Belts that might fit a mk3 non-A/C setup:
These are six-rib serpentine belts - that's what the 6pk means. Measurements are in mm)
PROPER belt - Continental 6PK 0894 (this belt has 6 ribs, and it is 894mm long)
other belts:
DAYCO 5060390 (it's 6pk by 0990mm)
DAYCO 0560455 (it's 6pk by 1155mm) and I don't think this is right!
DriveRite 390K6
Gates 6708 or K060388 or K060390
VW part number 999.192.283.50
Notice the spring:
That's what tensions the alternator.You loosen the pivot bolt,and the 19mm tension bolt,and let the spring tension the alternator,then you just tighten the bolts and roll!
