Page 42 of 99 FirstFirst ... 3240414243445292 ... LastLast
Results 411 to 420 of 990
Thread: Mk1 16v Project
  1. #411
    Jun 2006
    Orange NSW
    Quote Originally Posted by roccodingo View Post
    Yeah, early 80's was about when i was looking for one as well...
    Next trick is to find one....
    Hehe, i have saab connections...
    Er, well my old man does anyways. But if they are Vac advance that's not really what i want. I need progressive mechanical.
    Dad's going to get on to the saab bloke on monday about it.
  2. #412
    Perth. WA
    your intention is to run carbs yeah ???
    Unsure if you can run the std dizzy and use the knockbox with this, but i would be sure there is someone on the tex thats done this before...maybe worth a search...
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  3. #413
    Jun 2006
    Orange NSW
    Yeah mate, DCOE's.
    Knock box?? What like a detonation sensor?
    It will be running Bosch high energy ignition. A custom setup. Its half done already cause we were making one for the 8v, just need a suitable distributor.
    You'll have to help me out here.. As far as the electrical side of the 16v's go, i've got no idea. Never had anything to do with them before.
  4. #414
    Jun 2006
    Orange NSW
    No more guess work...
    Just got it today.
  5. #415
    Jun 2006
    Orange NSW
    The crank is now at the reconditioners being ground, flushed and balanced. Along with the H beam rods, which are going to be balanced to within .1gm.
    The crank journals are being ground specifically to size to give clearance of 2 thou (.05mm) on the mains and 2.5 (.0625mm) on the big ends.
    The main tunnels only varied by 2 tenths, so they will be ground to one size, but the rod big ends varied by almost 1 thou. Specifically they varied by .02mm across all 4, so they will be matched to their respective journals.
    These clearances are basically top tolerance (highest clearance) on the VW clearances given in the Bentley manual, which are pretty standard clearances.
    So.. To all the people telling me to get into gear.. There you go, the ball is still rolling.
  6. #416
    Jun 2007
    Eastern Suburbs Melbourne
    rolling like a match of lawn bowls but...
    i like volkswagens
  7. #417
    Jun 2006
    Orange NSW
    Slow but precise. So yeah, you're right.
  8. #418
    Sep 2007
    Slow but precise.
    so is that what you're mk1 will be like?
    *oh snap!!*
    87' MK2 GTI
    13' MK7 TDI
  9. #419
    Jun 2006
    Orange NSW
    Quote Originally Posted by jayjay View Post
    *oh snap!!*
    Righto mr "I'll just pay someone else to do it all for me".
  10. #420
    Sep 2007
    lol! i have no idea about porting and match porting! anything to do with proper machining. my tolerance is really low for how crap i am with a lathe.
    i uh.. made a machining joke.
    edit: LOL!!1
    87' MK2 GTI
    13' MK7 TDI
