Page 37 of 99 FirstFirst ... 2735363738394787 ... LastLast
Results 361 to 370 of 990
Thread: Mk1 16v Project
  1. #361
    Sep 2007
    what compression have decided on? is your head ready yet?!
    288 hydraulic tectonics cam!!!
    can i have your pistons yet?
    87' MK2 GTI
    13' MK7 TDI
  2. #362
    Jun 2007
    Eastern Suburbs Melbourne
    Ye-ah baby! That's what I'm talking bout. Hurry up and get this monster running would you!
    i like volkswagens
  3. #363
    Jun 2006
    Orange NSW
    Quote Originally Posted by jayjay View Post
    11.0:1. That's about the limit for pump fuel and carbies with no ECU controlled ignition system i think.
    Yeah you can have my pistons. I just need to get the invoice so i can tell you how much! I keep forgetting. I'll PM you my phone number so you can text me and remind me, K?
  4. #364
    With those cam's & 11:1CR, you'll get it idling around 1000rpm easily.
    Remember my 276 could idle no problem's at 900rpm.
    Just a bastard in traffic!
    288's should still idle around 1000rpm.
    It's when you get into the 300+, you need to run a high idle.
  5. #365
    Jun 2006
    Orange NSW
    Quote Originally Posted by golfworx View Post
    Yeah, that is true for single valve engines. Multi valve engines are a little different.
    As you know, it's all about air speed. I'm going to reserve my judgement till i get it going because i'm not quite sure what it will be like.
    Due to the fairly large inlet ports, large carburetor venturi's etc, i'm not sure i'll be able to let it idle that low without fouling plugs due to poor atomisation, charge burn and flame speed at those RPMs.
    Having said that, you might be spot on, too, Tim.
  6. #366
    Good call.
    Just don't want to have to screw that idle up that far that is running on the transfer slot's though. (Thinking of a Holley. Not sure on Weber's)
  7. #367
    Jun 2006
    Orange NSW
    Good call.
    Transfer slots? (Never had anything to do with holleys!)
    The idle should be fine if i have to wind it up a little. It doesn't really worry webers in my limited experience. I mean, you don't get off the idle jets till about 1/3 throttle..
  8. #368
    Cool.
    The only weber's I've had anything to do with are Escort & XF Weber's & also the ones you cook on!
    On a Holley, there's transfer slot's that help it progress from the idle circuit to the main circuit along with the accelerator pump's help as well. There's also the power valve which is like a vacuum operated fuel on/off switch.
  9. #369
    Sep 2007
    high idle with single cams..? more than 300 degrees.
    87' MK2 GTI
    13' MK7 TDI
  10. #370
    Jun 2006
    Orange NSW
    More progress. (Well not really, just more stuff, haha.)
    My lightweight lifter finally arrived after a crap fight with the US supplier we got the stuff from!
    I got the oil cap I wanted off Aydan last weekend too, very happy.
    Also scored a Louvre off Josh and Jarred at the same time! Woo!
    And this shot.. Well, its a tease for Tim. hehe.
