Did a little more tonight. I went to fit the head studs to the block the other day and the threads had a little corrosion etc in them and the studs were binding on them. I tried blowing them out but that didn't seem to work.
So, this arvo i made my own TPR Gingerbeering patented thread cleaner outerer. I just got an old 1.6 head bolt and ground 2 opposing flutes on it on the offhand grinder. If you don't have access to one, you could just use an angle grinder and be careful.
I would have just used a tap for this, but the bolts are 11mm dia by 1.5mm pitch. Why didn't they just use 12mm?
Anyway time for pics.
Here's the block with all the studs in and the torque plate slipped over the top.
I just wanted to make sure i didn't screw up on the dimensions when i made it. Thankfully, i didn't.
And here's a shot of the bolt i modified. Its a little hard to see.
