Page 16 of 99 FirstFirst ... 614151617182666 ... LastLast
Results 151 to 160 of 990
Thread: Mk1 16v Project
  1. #151
    Camden, Sydney
    Are you doing this to a 4 door??
    Schweet, there are not enough 4dr 16vs.
  2. #152
    Jun 2006
    Orange NSW
    Gees Matt, you didn't JUST notice that did you??
    Yeah i'd like to do a 2 door one day but too many people do 2 doors because its "the go". I thought i told you i had a 4 door? Maybe not..
  3. #153
    Jun 2007
    Eastern Suburbs Melbourne
    year 4 door FTW, i like em, in fact I didn't even want a 2dr. I just happened to get one. thats all. besides that. It's looking good, and flag mirrors are scweet too!
    i like volkswagens
  4. #154
    Jun 2006
    Orange NSW
    Yeah i decided the big mirrors were too bulky and the drivers side one was old and the passenger side one was an aftermaket one and it was just crap and i was unhappy with it, so i though stuff it. They're going.
    I wanted to put the flags back on it to neaten it up and keep with the subtle thing i've got going.
    Unfortunately it will only be subtle when its stationary and the engine isn't running.
  5. #155
    Jun 2006
    Orange NSW
    Ok, well i'd like to get over 200 at the flywheel, which should be achievable.
    Yeah the rods are 450 grams total, and the L19 bolts should be more than enough. Usually the bolts break before the rods if you don't use good stuff..
    Yes the exhaust valves are swirl ground and inconel.
    Silky said with a 4 cyl you don't need to balance the crank with bob weights, so the crank will be balanced static (its going to be out by HEAPS after i knife edged it). I will be getting the rods balanced to within .1gm and the flywheel/clutch will be balanced, obviously. I'll be getting silky to organise all that because (as you would appear to have enough knowledge to know) an awesome engine that has been badly balanced can turn into a real heap real fast.
    Oh, and i don't mind sharing, we aren't competing in the same racing class in which i need those extra couple of tenths over you.. (Ah, the ways you learn to keep secrets in kart racing...) Ask me anything and i'll answer honestly. Thats why i like this forum, everyone is eager to help eachother.
    You sure will have to have your crank and flywheel balanced after lightening and knife edging. Of the three cranks i have knife edged ( i did my forged stroker crank yesterday he he) they were all out at least 30 grams and the flywheels a similar amount! But static balancing is not enough it needs to be dynamically balanced properly at 500 rpm. If it is out you risk bearing damage at high rpm or in the worst case sinario a spun main and ka boom! Interestingly i have run four 86.4mm stroke cranks on the balancer and from the factory they were within 3 grams out of balance! You only need bob weights on 6 and 8 cylinder cranks
  6. #156
    Jun 2006
    Orange NSW
    Quote Originally Posted by twin eng, twin turbs View Post
    Sorry static i meant as in no bob weights (because like you said you don't need them on a 4 cyl), Silky is going to get everything dynamic balanced in Canberra.
  7. #157
    Jun 2006
    Orange NSW
    You should post some pics of your engine goodies like bonks head job he gave you he he on your cylinder head that is! So do you want a ride to the nats this year guaranteed we will get there fast! Ill even let you drive the turbs mk2. Is tom coming?
  8. #158
    Jun 2006
    Orange NSW
    Haven't got the head back yet, otherwise i would have many pics so i could boast about having one of the best 16v heads in australia . I'm taking the Karmann Ghia to the nats this year, but i'll take you up on the drive. .
    Got my bearings today (again, thanks Andrew!) and fitted my rod bearings. I'll fit the mains next week and mic everything up so that i can get the crank individually ground to exact size to give it top tolerance (highest) clearance on each journal, a must for a high revving engine.
    I've also been offered a part time position as Race Engineer for a guy who runs a V8 supercar in the Fujitsu series, which should be some fantastic experience aswell as a good boost in my weekly income.
  9. #159
    dude mega jealous of you right now!!!!
    i wanna see this car when im up in sydders and have a few cold bevvies mulling over it
  10. #160
    Jun 2006
    Orange NSW
    Quote Originally Posted by GoLfMan View Post
    Its JUST a mk1 4 door you know? I like it and i'm happy with what i'm doing, but its nothing that flash. Except the donk, it'll be pretty serious. Once i'm finished i'm going to build a full on race 1.8 16v. Solid lifter head light weight everything 9500rpm type stuff.
    Edit: Having said all that, i'm glad theres other people that like it too. Thanks for the complements.
