Ok, well i'd like to get over 200 at the flywheel, which should be achievable.
Yeah the rods are 450 grams total, and the L19 bolts should be more than enough. Usually the bolts break before the rods if you don't use good stuff..
Yes the exhaust valves are swirl ground and inconel.
Silky said with a 4 cyl you don't need to balance the crank with bob weights, so the crank will be balanced static (its going to be out by HEAPS after i knife edged it). I will be getting the rods balanced to within .1gm and the flywheel/clutch will be balanced, obviously. I'll be getting silky to organise all that because (as you would appear to have enough knowledge to know) an awesome engine that has been badly balanced can turn into a real heap real fast.
Oh, and i don't mind sharing, we aren't competing in the same racing class in which i need those extra couple of tenths over you.. (Ah, the ways you learn to keep secrets in kart racing...) Ask me anything and i'll answer honestly. Thats why i like this forum, everyone is eager to help eachother.
