Ross,
Everyone has their own way of doing things but this is how I was taught.
I wash the block with HOT water and dish soap. I use a brush and make sure I get
all of the locations around the cam area. I then pressure wash the entire
block. If I find anything I do it over. When the block is clean I blow all
the water off and immediately spray the internal areas with Marvel Mystery
Oil. I wipe down the cylinder walls with the same oil until I don't get any
residue. Then I wipe all of the bearing areas and blow out oil passages.
I don't paint anything because I had a bad experience where all the paint
came off during a race-in sheets. If no Marvel oil is available I use ATF.
Jay
