And this is revving the back out of summat!
http://www.youtube.com/watch?v=mv42vKGJl64&NR=1
wow, that's patience, 5 days! I think it'll look pretty trick once you're done
Ok, well the wrinkle finish went to crap cause it stained when i polished the ribs and i couldn't get it out. Also it was uneven because half way through painting it the can started leaking so i could get even cover .
So, i wet blasted it again and repainted it with high temp flat black. Came up looking really good i think..
Also, today i lightened my flywheel, which came up well.
If anyone is interested i can machine flywheels for them, too.
Nice project Should go well with that engine
Ok, so yesterday i got some more stuff done on the braking department. I started fitting the rear disc setup that i got hold of. I've cleaned all the parts up and painted them and i also machined the discs and cleaned them up too. At the moment i'm just doing one side so i can figure out how i'm going to do it. This way if i make a mistake it's half as bad.
Here's a pic of the setup on the rear end (Minus the disc..)
And here's the freshly machined and painted discs.
