I assume you mean the cam cover? Black wrinkle finish.
Printable View
And this is revving the back out of summat!
http://www.youtube.com/watch?v=mv42vKGJl64&NR=1
Primed the cam cover yesterday and painted it today.
http://img91.imageshack.us/img91/211...mallcu3.th.jpg
Tomorrow i'm going to rub the ribs back and re polish them. I'l post pics when it's done. This wrinkle finish paint takes a while to set properly, the can says 5 days to fully harden! It had started to wrinkle a little when i left the workshop.
wow, that's patience, 5 days! I think it'll look pretty trick once you're done
Ok, well the wrinkle finish went to crap cause it stained when i polished the ribs and i couldn't get it out. Also it was uneven because half way through painting it the can started leaking so i could get even cover :mad:.
So, i wet blasted it again and repainted it with high temp flat black. Came up looking really good i think..
http://img85.imageshack.us/img85/359...mallag0.th.jpg
Also, today i lightened my flywheel, which came up well.
http://img210.imageshack.us/img210/8...mallji2.th.jpg
If anyone is interested i can machine flywheels for them, too.
Nice project :D Should go well with that engine :)
Ok, so yesterday i got some more stuff done on the braking department. I started fitting the rear disc setup that i got hold of. I've cleaned all the parts up and painted them and i also machined the discs and cleaned them up too. At the moment i'm just doing one side so i can figure out how i'm going to do it. This way if i make a mistake it's half as bad.
Here's a pic of the setup on the rear end (Minus the disc..)
http://img152.imageshack.us/img152/4...mallyk8.th.jpg
And here's the freshly machined and painted discs.
http://img152.imageshack.us/img152/2...mallmv0.th.jpg
