Originally Posted by
golfworx
Whooooo Hell Yehhhhh!!!
Very nice Blower with alcohol injector's.
Steering wheel for a dragster attendant,
A couple of old school wooden handles for a parachute, brake or fuel shut off.
If your at Nat's, we'll have to catch up for a chat. Would like to know more about this Hemi!
Where about's did you get your windage tray from?
I'm currently waiting on mine to arrive form the US. Cost me all of $38 US, as I brought a large shipment of part's.
I like the oil pickup mod. May do this to mine when I fit the tray!
Excellent explanation with the bearing's & ring's too!
Another thing with setting up ring gap, is what the engine is used for. A turbo engine should run a higher gap & from what I've learn't, a straight NOS race engine run's the largest gap (0.0070" - 0.0073 for every inch of bore), with a blown race engine right behind it (0.0060" - 0.0063").
Different manufacturer's also run different gap's to. Most company's run a larger top ring gap than a second.
JE on the other hand run a larger second ring gap to stop ring flutter on high rpm.
Another suggestion for race motor's is to gas port the piston crown's, which mean's you can use low tension ring's. This allow's the engine to spin up faster, as there's less drag/resistance. A engine's worst enemy for making power.
