Are you doing this to a 4 door??
Schweet, there are not enough 4dr 16vs.
Printable View
year 4 door FTW, i like em, in fact I didn't even want a 2dr. I just happened to get one. thats all. besides that. It's looking good, and flag mirrors are scweet too!
Yeah i decided the big mirrors were too bulky and the drivers side one was old and the passenger side one was an aftermaket one and it was just crap and i was unhappy with it, so i though stuff it. They're going.
I wanted to put the flags back on it to neaten it up and keep with the subtle thing i've got going.
Unfortunately it will only be subtle when its stationary and the engine isn't running. :D
You sure will have to have your crank and flywheel balanced after lightening and knife edging. Of the three cranks i have knife edged ( i did my forged stroker crank yesterday he he) they were all out at least 30 grams and the flywheels a similar amount! But static balancing is not enough it needs to be dynamically balanced properly at 500 rpm. If it is out you risk bearing damage at high rpm or in the worst case sinario a spun main and ka boom! Interestingly i have run four 86.4mm stroke cranks on the balancer and from the factory they were within 3 grams out of balance! You only need bob weights on 6 and 8 cylinder cranks
You should post some pics of your engine goodies like bonks head job he gave you he he on your cylinder head that is! So do you want a ride to the nats this year guaranteed we will get there fast! Ill even let you drive the turbs mk2. Is tom coming?:cool:
Haven't got the head back yet, otherwise i would have many pics so i could boast about having one of the best 16v heads in australia :D. I'm taking the Karmann Ghia to the nats this year, but i'll take you up on the drive. :).
Got my bearings today (again, thanks Andrew!) and fitted my rod bearings. I'll fit the mains next week and mic everything up so that i can get the crank individually ground to exact size to give it top tolerance (highest) clearance on each journal, a must for a high revving engine.
I've also been offered a part time position as Race Engineer for a guy who runs a V8 supercar in the Fujitsu series, which should be some fantastic experience aswell as a good boost in my weekly income. :D
Its JUST a mk1 4 door you know? I like it and i'm happy with what i'm doing, but its nothing that flash. Except the donk, it'll be pretty serious. Once i'm finished i'm going to build a full on race 1.8 16v. Solid lifter head light weight everything 9500rpm type stuff.
Edit: Having said all that, i'm glad theres other people that like it too. Thanks for the complements. :)
