Yeah there's two bearings. One at the front, one at the back. Even if it looks fine it's probably still knackered.
You need to take the cap off and take the split pin out, then undo the nut. The drum then comes out/off.
You'll need to knock the outer races out with a pin punch and a hammer, from the inside out. By that, i mean you have to push them out from the opposite side if you get what i'm trying to say. Make sure you tap it one side, then the other etc to keep it square as it comes out.
Once they're out, give the whole lot a good clean and bash the new races back in the same way. Don't worry about hurting the race hitting it back in.. You won't.
Then you need to pack the bearings as i've stated earlier.When you reassemble the whole lot, you want to put just a little bit of pre load on the bearings, enough to put just a little resistance on the drum when you rotate it.. So you want it to be "firm", not "tight".
Hope that helps..
Stolen from danjreeds site, how to pack bearings:
http://faculty.ccp.edu/faculty/dreed...Vol2Issue3.pdf
You can lube the drum up a bit with grease to help it when u put the races in
well done mate.
your odometer will be easy to fix, just pull out the clocks and take the back off your speedo panel and there is a small worm gear set. I bet the driving gear for the odometer has slipped clear of the worm gear. You can just tap it back on and it will work.
If you wasnt a more permanent fix, maybe add a drop of superglue or something to keep it on there.
Bearings are easy, just take your time and don't tighten the nut too much. If you have a manual, read the procedure for checking the play in the bearing.
Top work
TDI mk1 on the road!!
cheers guys. Now I just need to find the motorvation to get out there in the cold!
Maybe later this arvo I will find some time!
I've fixed up a few things since last post. still have a bearing noise [only half as bad now]. looks like I"ll need to whack the inner bearing out as well and re pack that, or do a swapsy with the 76er even.
Fixed up the odo, well didn't fix it cause I couldnt' be bother, so I used the one outta my 76er as well.
Last "tank" [only 200 odd clicks] I got a fuel econ of 6.00L/100km. Which I was a tad disappointed with. It was a fair mix of driving though including heaving traffic, freeway, and a fair amount of sooting people
Something I need to do tomorrow, in prep for the road trip, is take a few spares and tools. Any one have any recommendations?
So far it's:
oil
water
spare hoses
fuses
tow rope
spare tyre
cable ties [of course]
anything I should add to that?
Cheers guys.
I get about 6l/100km on my turbo so go figure. Should be good seeing this car up in person
I think uve got everything on that list. Maybe bring some eleccy tape and duct tape too...
Torch
Jumper leads
Pete
crazy hat and a mexican midget that can climb out the window and fix the car while its still driving!
