Page 22 of 43 FirstFirst ... 12202122232432 ... LastLast
Results 211 to 220 of 423
Thread: Mk 1 Diesel Project
  1. #211
    Aug 2006
    Melbourne VIC
    Quote Originally Posted by GoLfMan View Post
    my mk1 gauge would have plummeted to half
    Yes a combination of your heavy right foot and Webber is very fuel efficent
  2. #212
    Quote Originally Posted by Water Boy View Post
    negative, add to that clutch slip, a weber that isnt supposed to be on this engine (my DCOE is out of action for a tad ) sighhh
    so many things to fix so little time
  3. #213
    Jun 2006
    Orange NSW
    yea sure does preeny. Cheers mate. This is the bearing just under the cap yea?
    Dom, it's hard to see... accelerating is a bit of a tough one in a GLD rememeber...
    Yeah there's two bearings. One at the front, one at the back. Even if it looks fine it's probably still knackered.
    You need to take the cap off and take the split pin out, then undo the nut. The drum then comes out/off.
    You'll need to knock the outer races out with a pin punch and a hammer, from the inside out. By that, i mean you have to push them out from the opposite side if you get what i'm trying to say. Make sure you tap it one side, then the other etc to keep it square as it comes out.
    Once they're out, give the whole lot a good clean and bash the new races back in the same way. Don't worry about hurting the race hitting it back in.. You won't.
    Then you need to pack the bearings as i've stated earlier.When you reassemble the whole lot, you want to put just a little bit of pre load on the bearings, enough to put just a little resistance on the drum when you rotate it.. So you want it to be "firm", not "tight".
    Hope that helps..
  4. #214
    Oct 2006
    Stolen from danjreeds site, how to pack bearings:
    http://faculty.ccp.edu/faculty/dreed...Vol2Issue3.pdf
    You can lube the drum up a bit with grease to help it when u put the races in
  5. #215
    Nov 2005
    newcastle
    well done mate.
    your odometer will be easy to fix, just pull out the clocks and take the back off your speedo panel and there is a small worm gear set. I bet the driving gear for the odometer has slipped clear of the worm gear. You can just tap it back on and it will work.
    If you wasnt a more permanent fix, maybe add a drop of superglue or something to keep it on there.
    Bearings are easy, just take your time and don't tighten the nut too much. If you have a manual, read the procedure for checking the play in the bearing.
    Top work
    TDI mk1 on the road!!
  6. #216
    Jun 2007
    Eastern Suburbs Melbourne
    cheers guys. Now I just need to find the motorvation to get out there in the cold!
    Maybe later this arvo I will find some time!
    i like volkswagens
  7. #217
    Jun 2007
    I've fixed up a few things since last post. still have a bearing noise [only half as bad now]. looks like I"ll need to whack the inner bearing out as well and re pack that, or do a swapsy with the 76er even.
    Fixed up the odo, well didn't fix it cause I couldnt' be bother, so I used the one outta my 76er as well.
    Last "tank" [only 200 odd clicks] I got a fuel econ of 6.00L/100km. Which I was a tad disappointed with. It was a fair mix of driving though including heaving traffic, freeway, and a fair amount of sooting people
    Something I need to do tomorrow, in prep for the road trip, is take a few spares and tools. Any one have any recommendations?
    So far it's:
    oil
    water
    spare hoses
    fuses
    tow rope
    spare tyre
    cable ties [of course]
    anything I should add to that?
    Cheers guys.
    i like volkswagens
  8. #218
    Oct 2006
    I get about 6l/100km on my turbo so go figure. Should be good seeing this car up in person
    I think uve got everything on that list. Maybe bring some eleccy tape and duct tape too...
  9. #219
    Boronia VIC
    Torch
    Jumper leads
    Pete
  10. #220
    Eastern suburbs of Melb
    crazy hat and a mexican midget that can climb out the window and fix the car while its still driving!
