Page 41 of 43 FirstFirst ... 313940414243 LastLast
Results 401 to 410 of 423
Thread: Mk 1 Diesel Project
  1. #401
    I don't really understand your reasoning on this?
    You have "coilovers" which are "height adjustable"
    You also have coilovers which don't have compression or rebound adjustment.
    No matter if you wind them up or down, I'm pretty sure the ride will be the same. Like Dom's mk1. (don't have to say it, you already know)
    Confused???????
  2. #402
    Oct 2005
    Nowra, NSW
    I guess the logic is you don't have to wind the coilovers down so far to get low so you would therefore have more suspension travel?
    correct me if i'm wrong.
  3. #403
    Quote Originally Posted by static1800 View Post
    Your have a good point & it does make sense.
    But normally with coilovers, you can wind the car right down to the point of driveshafts rubbing etc., & still have good suspension travel (bar the driveshafts smashing on the framework) without getting near touching the bumpstops.
    I've had mine wound nearly all the way down & till had a fair bit of room lift before hitting the bump stops.
    Plus with how stiff the springs rates normally are on coilovers, there isn't a hell of alot of travel to start with.
    If it's an everydayer that you travel alot of km's each day, I'd be looking more into some balljoint extenders & tie rod flip kit to eliminate bump steer with big & wider wheels, as that is a pain in the arse!
    Obviously with stock sized wheels & tyres, there isn't a great deal of this problem, if any.
  4. #404
    Oct 2005
    Nowra, NSW
    I guess one thing also is the rear's will still be standard so you don't get the travel gain there, unless that never much of an issue?
  5. #405
    Jun 2007
    Eastern Suburbs Melbourne
    It's not night and day, but the extra travel in the suspension makes the front end slightly less harsh.
    I wanted to be about 20mm lower than what I was before, but I knew winding down to that height would compromise drive quality (severly) as I had previous experienced in Dom's car. The spacers mean I've got an extra ~40mm travel, meaning I can raise the coils for a slightly better ride & still have the car lower. Now I need a shortened driveshaft (LHS), clearance for the RHS driveshaft, beat out the green gaurd (rubs slightly) and possibly a spare sump.
    I'd love to get ball joint spacers & flipped tie rods, but the coin doesn't allow that atm.
    Hope this explains it. And yes, WCHLVR (Terry) makes them. You can buy them through his site. Fantastic customer service & an innovative products to boot! http://www.oldskoolvw.com/
    i like volkswagens
  6. #406
    Scotland
    I noticed a HUGE difference in drive quality between a -60mm and -80mm drop.
    Went from reasonably nice to OMG! WTF??
    but I got used to it quickly cos I loved the stance
    Will be good to hear the results of fitting these...
  7. #407
    Jun 2007
    You're spot on there Ross.
    Now it's like having the better ride quality with the better looks! great huh?
    i like volkswagens
  8. #408
    Aug 2006
    Melbourne VIC
    From last night:
  9. #409
    Jun 2006
    Orange NSW
    Yeah it definitely needs to be lower than where you have it now..
  10. #410
    Jan 2009
    south west sydney
    i think you should just go for the bags
