Page 34 of 43 FirstFirst ... 243233343536 ... LastLast
Results 331 to 340 of 423
Thread: Mk 1 Diesel Project
  1. #331
    Oct 2005
    Nowra, NSW
    yep.
    When I win the 90Million tonight in the lottery, you sure know what I'll be buying first!
    Smart choice, I would buy the Vectra too
  2. #332
    Nov 2005
    Quote Originally Posted by MiKe1_golf View Post
    how many cars do you need? looks like you're stuck in a traffic jam there
    its at my joint, my mum has some stupid tea party/luncheon thingy, we put my wheels on to see what they looked like on his car and if they will scrub with rolled lips
    cheers
    dom
  3. #333
    Jun 2007
    Eastern Suburbs Melbourne
    after spending some time on the audi last week, I got out and checked a few things with the diesel today.
    and I'm perplexed.
    Whilst driving at night, in the cold, was when I had problems.
    I started the car up, and let it idle, while i checked these things. With the lights on, voltage dropped ~ .7V. whilst having the heater on (full-ball) voltage dropped around ~.5V again. both times, the voltage dropped, but was still increasing (ie being charged by that alt., or atleast held steady)
    Now, whilst having both on is where I ran into troubles. Voltage dropped from ~14.3 (with everything off,) to ~12.9V and started decreasing! . This would explain the issues i've been having, but I'm not really sure how to fix them!
    Is it poor earths in both cases. is the combination of having both heater and lights on just too much current/voltage draw?!
    Any ideas?
    I've cleaned up the headlight earths quickly the other day. (well tried atleast)
    TIA
    i like volkswagens
  4. #334
    Oakleigh VIC
    Start measuring current across the fuses.
    Pull each fuse out in turn and put your DMM across the fuse terminals. Make sure your DMM is set to the 10Amp range and the leads are plugged into the right sockets.
    I'm begining to suspect that your heater fan is starting to sieze up. Has the heater fan fuse been replaced by a heavier one by any chance?
    I've found quite a few siezed fan motors, as the bearings dry out they get harder and harder to turn which makes the current go up and up. The fuse box often gets damaged too by the excessive current.
    You can get them lubed up again with some of that INOX spray, but you'll need to pull the motor out to do it. (I use INOX because it doesn't leave a smell in the cabin). Spin it up on the bench to test it. It should spin freely by hand.
    I'll see if I can dig out my DC clamp meter for you to have a play with.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  5. #335
    Feb 2007
    I havnt been following the issue closly so sorry if i missed this but have you upgraded your Big3?
    MK1 GLS 3door
    A4 B7 2.0T
  6. #336
    Jun 2007
    Quote Originally Posted by Spyda View Post
    nope, but seeing as the car is standard, and they're all in good nick (ie not rusty, good contact, clean) this shouldn't be an issue. If I had a stereo or something yea, but on a standard car, I don't think it'd be the cause.
    Thanks Pete, I'll get out tomorrow and fiddle with the fuses, if I can find the time, I might spend all day playing with my new welder
    EDIT: should be an 8amp fuse shouldn't it?
    and what am I looking for when I put the DMM across the fuses. I'm guessing less than 8 amps (providing it's an 8 amp fuse socket). Thanks Pete.
    i like volkswagens
  7. #337
    Oakleigh VIC
    Your alternator only puts out 50 (?) Amps.
    You're looking to see if the total current through all the fuses added up is less than 50amps or the battery won't charge.
    I don't recall the fuse rating for the fan, I'll have to look it up but I'm a bit busy tonight.
    Pete
    7? MK1 Caddy
    12 Amarok
  8. #338
    Jun 2007
    thanks pete. I'll give it a crack tomorrow.
    i like volkswagens
  9. #339
    Jun 2007
    So I'm pretty sure I ended up getting most of the electical problem's, don't really recall, cause I havn't been driving much (holidays) and I have an alignment or other issue causing a vibration that makes driving much less than pleasurable.
    Anyways, here's a taste of what's to come:
    i like volkswagens
  10. #340
    Jun 2007
    hmm....
    I think I have a busted CV.
    hmmm....
    regardless.
    i like volkswagens
