Page 32 of 43 FirstFirst ... 22303132333442 ... LastLast
Results 311 to 320 of 423
Thread: Mk 1 Diesel Project
  1. #311
    Aug 2006
    Melbourne VIC
    That was part of my Yr12 Physics exam...
    Oscilloscope: a type of electronic test instrument that allows signal voltages to be viewed, usually as a two-dimensional graph of one or more electrical potential differences (vertical axis) plotted as a function of time or of some other voltage (horizontal axis).
    Geeeeeeeezzzzzzzz im gooooooooooddddddd
  2. #312
    Feb 2007
    Quote Originally Posted by Water Boy View Post
    NEEEEEEEEEEEEEEEEEEEEEEEEERD
    i cant talk i did yr12 physics in yr11 haha
    MK1 GLS 3door
    A4 B7 2.0T
  3. #313
    Jun 2007
    Eastern Suburbs Melbourne
    Haha James, but I do know what an os-silly-scope is. I'm supposedly being an engineer remember
    Pete, this was the reason for checking the current:
    Quote Originally Posted by ontarv View Post
    if your multi meter has amps select 200 mamps
    remove one battery lead conect multi meter to battery post and
    the other lead to the lead
    have everything off the multi meter should not read over .04 mamps
    if it does remove one fuse at a time till you find the curcuit with a drain
    hope that helps you Jarrad
    Actually, I did it wrong anyway, so ignore that anyway.
    Should I try that spare alternator that you gave me, and see if the AC V drops down?
    i like volkswagens
  4. #314
    Aug 2006
    Melbourne VIC
    Its like one of the only definitions I remember from the exam
  5. #315
    Boronia VIC
    Yep.
    Also look for voltage drops with that shiny new DMM.
    Check the voltage between the body of the alternator and the -ve terminal of the battery for example. It should be 0.0v. If it's anything else, start replacing earth straps and cleaning contacts until it's 0.0v
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  6. #316
    Jun 2007
    Swapped the alternators this morning (afternoon really)
    Took these measurements.
    Old alt.
    car off: 12.27V
    car running: 13.6V(--) (slowly increasing) and 29.3 V(~)
    'New' Alt.
    Car off: 12.29V
    Car running 14.2V(--) and 30.9V(~).
    So the new alt is stronger, but the V(~) didn't change drastically.
    I've just gone out and check the Voltage between the alt body and -ve terminal and it was 0.07V (--), so after lunch I'm going to go out and checking the earths. I might even buy some new straps etc.
    I'm also planning on taking the batt to where I bought it, to get it checked, as I bought it about 355 days ago. Hopefully if it's damaged at all, I can get a new one under warranty.
    i like volkswagens
  7. #317
    Nov 2005
    Jan 2009
    south west sydney
    WTF atleast 10 characters.... all i wanted to say was
  9. #319
    suits it!!!! get your wallett out Jarred
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
  10. #320
    now that looks phat
