Page 31 of 43 FirstFirst ... 21293031323341 ... LastLast
Results 301 to 310 of 423
Thread: Mk 1 Diesel Project
  1. #301
    Boronia VIC
    I'm pretty sure I had mastered the multimeter,
    There are many ways to use a multimeter (that's what the multi bit means)
    Pop quiz. What do you use the AC (~) range on your multimeter for in the context of diagnosing auto electrical gremlins?
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #302
    Jun 2007
    Eastern Suburbs Melbourne
    you don't, you use the DC range for starters.
    but I use the 20 V(--) range
    i like volkswagens
  3. #303
    Boronia VIC
    Sorry to crush your enginnering spirit there Jarred, but that's a 2 or maybe three phase AC alternator in your car.(alternators make - alternating current)
    The AC is made into DC (more or less) by a bunch of diodes inside the alternator.
    There will always be some AC ripple present when charging. The battery smothes most of the ripple.
    If you can measure a lot of AC the diodes are shot and it's only a matter of time before the battery is too.
    See? There's one new way to use that meter already.
    Pete
    7? MK1 Caddy
    12 Amarok
  4. #304
    Jun 2007
    gah! smarty pants.
    thats my new thing I've learnt for today then.
    I'll give it a go tomorrow once the batt is charged, and the car is running.
    actually, I should have read the question properly.
    "diagnosing auto electrical gremlins"
    Most I can do is check the voltage on the battery. Although aparently I can't do that either! hahahahha LOL.
    i like volkswagens
  5. #305
    Jun 2006
    Orange NSW
    That's why Pete's a big shot Moderator and you're not Jarred.
    Thanks for that tip Pete.. I didn't know that! (Never needed to..).
  6. #306
    Gosford Central Coast NSW
    more like its 'cos Pete is a big shot electrical Guru!
    thanks pete, another trick up the sleeve
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
  7. #307
    Jun 2007
    So I went out to the garage this morning, to find the charger off, and a note next to it. "still charging at 4amp. NO GOOD" from Dad. Crap I thought.
    Got my multimeter, and the batt measured at 12.3V, so I thought, bugger it, I'll give it a go. Pop it in the car and it starts up, no worries.
    Get my trusty multimeter out, on 20 V(--) it reads 13.5V, indictating the alt is still charging properly. Whack it on 200 V(~) (smallest setting for AC) and it read steady at 28.6 V.
    Current also measured at 0.00mA too.
    I'm going to see if I can find the receipt for the battery, it's only about 14months old, so it shouldn't have packed it in by now.
    EDIT: Found the reciept bought it 2/7/08, should still be in warrenty (spelling?) should it come down to that.
    i like volkswagens
  8. #308
    Scotland
    Your car looks spot on! Simple but effective styling wins all the time.
    How low do you think it is now in mm's?
    I had to raise mine up a little when it was -80mm as the driveshafts were really close to the chassis. Mine has had a tiny notch cut out for clearance but wouldnt want to cut any more off and weld a pipe section in like some people have done..
  9. #309
    Jun 2007
    Hi Ross.
    Cheers, I don't know exactly how low it is. I know it's not hitting the driveshaft yet though. I'd estimate at about 3 inches or 75mm of drop.
    Once the suspension settles, I'm going to go out and set it up properly, make sure everything is clearanced etc.
    i like volkswagens
  10. #310
    Boronia VIC
    That's a lot of AC. I wouldn't expect more than about a volt or so. You might have a shorted diode in your alternator. An oscilloscope would be the next diagnostic tool I'd apply. The wave form will quickly give away what's happening.
    0.00mA ? Where and how did you measure this?
    Pete
    7? MK1 Caddy
    12 Amarok
