Page 24 of 43 FirstFirst ... 14222324252634 ... LastLast
Results 231 to 240 of 423
Thread: Mk 1 Diesel Project
  1. #231
    She has realy come up a treat man, congrats.
    Now drop it already!!!
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
  2. #232
    Jun 2007
    Eastern Suburbs Melbourne
    cheers Neil. I still havn't polished it completely yet,. you can tell in some of the pics.
    I'm still having an issue with the batt/alt, as I ran out of electricity last night again. Had the lights on for maybe an hour, without the car on. Battery was at 11v.
    I swapped batt's with Josh, so I could get home, and now my batt [after josh's alt charging it last night] is back up to 12.6ish v. When running, it's reading 13.6-7v, which would imply that the alternator is still working.
    The accesory belt, is practically the same tightness [spelling] as on Joshs. I'm a bit stumped really, do I have an open circuit in my car somewhere perhaps? or are dead glow plugs sapping too much juice?
    where should I start looking?
    EDIT: 7:00pm, just checked the battery, 12.35v. Will check again tomorrow, see what's what.
    i like volkswagens
  3. #233
    Apr 2006
    Melbourne, Victoria
    Your car looks sensational. Well done! Your hard work has been worthwhile.
    Beige 79 Mk1 GLD White 76 Mk1 LS 3 door
    White 68 Alfa 1750 Berlina Champagne 91 Alfa 75
    Red 09 9N3 Polo TDI White 2010 Skoda Octavia Combi TDI
  4. #234
    Jun 2007
    checked the voltage now [11am] and it's 12.26v. which is 0.09v in about 10hours. should i be concerned?!?
    i like volkswagens
  5. #235
    May 2006
    Maryborough Vic
    Talking
    if your multi meter has amps select 200 mamps
    remove one battery lead conect multi meter to battery post and
    the other lead to the lead
    have everything off the multi meter should not read over .04 mamps
    if it does remove one fuse at a time till you find the curcuit with a drain
    hope that helps you Jarrad
  6. #236
    jarred i had to do it....couldt help my self lol
    hope you like it.
    also edit in the center hub on the rear.
    also congrats with it. looks sweet.
    opps i just saw that i didn't crop the top bit out...but who cares..focus on the car lol
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
  7. #237
    Jun 2007
    nice one Gordan, thanks. now i really can't wait to do it in real life!
    Probably the exact stance i'll be aiming for. or maybe lower..
    i like volkswagens
  8. #238
    no worries Jarred!
    Yeah i cant wait aswell, shes going to look mint.
    Good luck.
    Golf GTI 1980
    Golf GLS 1979
  9. #239
    Jun 2007
    Quote Originally Posted by ontarv View Post
    i did this. multi meter initally read 1. [perhaps maybe as in overload for the 200mA setting.] Went through the fuses, [none are damaged] and pulled the 8th fuse [from the left] and then the reading went to zero. put the fuse back in and now the multi meter reads 0.00. did i just fix my first elctrical problem?!?
    alternator is charging, quickly fired her up, and the voltage jumped to 13.5sh. So all is well in that respect.
    i like volkswagens
  10. #240
    lower...... its about time you stopped being conservative and boring with your cars
