Page 21 of 43 FirstFirst ... 11192021222331 ... LastLast
Results 201 to 210 of 423
Thread: Mk 1 Diesel Project
  1. #201
    Jun 2006
    Orange NSW
    Congrats homie. Good to hear!
    Quote Originally Posted by WABIT View Post
    damn! that would have been a kick in the gooch!
    New Sig..
  2. #202
    nice work buddy...
    lol at preen at his sig.
    madogs.
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
  3. #203
    Jun 2007
    Eastern Suburbs Melbourne
    one issue I need to get some ideas on.
    Sounds like i've got a wheel bearing taht's being a bit tricky. Fronts are brand new, so I'm guessing rears are to blame.
    symptoms: it's your basic whomp whomp whomp, and drone/hum. Goes away when turning right, or leaning left rather.
    Solution? I'm geussing it's rear wheel bearings, I'm geussing that I'll be swapping bits over with the 76er and see how I go. or I've heard it could be tyres unevenly/badly worn. which they aren't. anything else cause this?
    Just have to fix a few rattles in the dash vents & this whomp, and it's should be pretty right. Have to keep fiddling with the wheel alignment, something isn't hunky dory there.
    oh yea, are GLD's prone to vibrating alot, esp through the steering wheel, just at idle?? anyone know what I mean?
    i like volkswagens
  4. #204
    Nov 2005
    wheel bearings usually get louder when accellerating, hpe this helps
    dom
  5. #205
    Jun 2006
    Orange NSW
    Sounds like its your right rear wheel bearing for sure. Just change the bearing (not a huuuuuge job) or swap the whole hub assy over from the 2 door if you're lazy.
    If you do replace the bearing, remember to pack it properly.
    Basically what you do is put some bearing grease in the palm of your hand, get the bearing and scrape the side of the cage through the grease hard against your palm, pushing the grease up in between the cage and the inner race. Do this working your way around the bearing as you go, from both sides.
    Make sense?
  6. #206
    S.E Melbourne
    Mine does at least
    It doesn't matter what car you drive.. If you're a complete wanker.. People still won't want to talk to you..
  7. #207
    Jun 2007
    yea sure does preeny. Cheers mate. This is the bearing just under the cap yea?
    Dom, it's hard to see... accelerating is a bit of a tough one in a GLD rememeber...
    i like volkswagens
  8. #208
    Jun 2007
    Quote Originally Posted by Whubbsie View Post
    Mine does at least
    cheers, i think we need to compare notes one day.
    i like volkswagens
  9. #209
    Aug 2006
    Melbourne VIC
    I can confirm guys it goes places. A trip to Altona and back and the guage only moved a mm
    Power is ummmm somewhere but who cares we did blocky of Deakin
  10. #210
    Quote Originally Posted by Water Boy View Post
    my mk1 gauge would have plummeted to half
