Page 18 of 43 FirstFirst ... 8161718192028 ... LastLast
Results 171 to 180 of 423
Thread: Mk 1 Diesel Project
  1. #171
    Jun 2007
    Eastern Suburbs Melbourne
    So. after spending a few days fiddling around with driveshafts and CV's and like, i've almost got everything back together
    got the wheels bearings pressed in this arvo, and the new CV boots were down yesterday. should be holding it's own weight again soon, i'm aiming to take it to roadworthy next week.
    pics to come when i charge the battery's!
    i like volkswagens
  2. #172
    Oct 2006
    sydney
    good news! By doing these things you wont have an issue and at its age they are common problems.
    i absolutely love how the car has turned out so clean the white is such an elegant colour.
    any plans on changing the wheels you always have steelies make this one different thats all its missing now
  3. #173
    Jun 2007
    Yea, I got some plans for some wheels.
    not sure I'll have them before nats, which is a bit dissappointing, but oh well. not sure how it'll be come nats, have to see how everything goes.
    I whacked the hubs in today, got it standing up on its own wieght again. Typical mk 1 though, fixed two things and found another 3 problems! Fitted up and bled the GTI brakes too. might need to re bleeed though. not quite hunky dory yet. and need to fix the alignment - bad!
    i like volkswagens
  4. #174
    Perth. WA
    Set the wheel camber first, then do your toe adjustment... looking good bud.
    Lots of MK 1 Scirocco's...
    Cheers,
    Grant...
  5. #175
    Jun 2007
    Quote Originally Posted by roccodingo View Post
    cheers Grant. just need to find a big shifter now...
    i like volkswagens
  6. #176
    Oct 2006
    U mean a shifter like this?
    Looking good tho jarred, i wish i was so productive as u im so bloody lazy!
  7. #177
    Jun 2007
    what a mad shifter! hahahaha
    hahahaha
    i like volkswagens
  8. #178
    Jun 2007
    found my shifter and fixed the alignment, sort of. The wheels don't 'sqwabble' or 'wander' but the steering wheel is still off centre, even though the car is going [almost perfectly] straight. Do I need to take off the wheel and centre it, or is that a big no no?
    I've only got adjust tie rod on one side...hmm..
    I've bit the bullet, and booked her in for roadworthy on thursday morning. only 24 days left, so i'm kinda pushing it! wish me luck.
    also, the deisels been a bit hard starting of late. I'm thikning glow plugs are going, as it needs two cranks to get going. & blows a big plume of smoke once it kicks over. Any way to test the plugs easily or something else I should look for? thanks deisel geeks!
    i like volkswagens
  9. #179
    Jarred, just take the wheel off and put it back on straight. Thats the way its supposed to be done
    p.s good luck brother
  10. #180
    Oct 2006
    check the glowplug fuse and the relay to see if uve got power. if yes, then im not sure of the correct way to test them but u can take them out and see if they heat up. once u take the bus bar off tho, you might as well replace them all as thats the toughest part of it all!!
    edit: here we go found this
    http://www.4crawler.com/Diesel/Cheap...lowPlugs.shtml
