Have a look at your gearbox code, looking at the web page you posted will tell you what colour gear you need. the gear will come of the cable with a tug.
Last year I bought home some scirocco 2 cables from UK and had the local speedo joint remove the plastic clip type speedo end and crimp on a thread end type.
Was an expensive excersise tho...
http://www.gsfcarparts.com/index.html
Golf cable 76141A ( ring and check length)
Scirocco cable 76156. long....
