Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 101
Thread: Mini Project: Save the Hooker... MK2 GTI 16v
  1. #21
    Dec 2008
    Bentleigh, Melbourne
    Quote Originally Posted by ranton-inc View Post
    What am i missing from the back of this intake mani!?
    a hose for one
    but those tapped holes, i have no idea. mine doesn't have anything there either
  2. #22
    Feb 2008
    New Zealand
    Quote Originally Posted by Stiggy_21 View Post
    a hose for one
    Haha thanks dude.. must be nothing then... hrrmm so where is the other lifting point on the engine .....
    Modfied the front bracket yesterday after work to work with the 02a quite simple just relocated one of the screwing lugs that normally hangs out down the bottom up to a higher point....
    Mounted the MK3 Gear Shift box
    The Back most point was later secured using a combination of Nutserts/RivetNuts and Cap Screws Strong as!
    Now on to sorting the Power Steering Lines.. this makes me a touch nervous...... and being lhd its a prick to bolt on and off the lines... have to get them shortened at the hose doctor.
    Almost finished with the Central Locking system.... and hoping to have the dash back in this weekend... that will signify a huge step in progress for me....
    Fitted up the New Temporary Wheel yesterday doo
    16x7 Technomagnesio ET30 Wheels (205/45/16)
    Im not in to super lows so hopefully this wont rub..
  3. #23
    keep up the good work!
  4. #24
    Feb 2008
    New Zealand
    Monday night was good got a reasonable whack done...
    - Exhaust Heat Sheild re installed
    My Girl was helping she had the vacuum out and lifted all the carpets and vacuumed the floor pan and also all the carpets the interior is spotless which is a bonus! and something that needed to be done so i can tidy all the wiring etc...
    While she was doing that I finally completed the Braking system on the front having to use a combination of mk4 Bora 4 Motion Brake lines and twisting the hard line around and bending the bracket the lines seem to be sweet and allow for the turning of the steering axle etc..
    Then my lovely assisted manned the brake pedal while I crawled underneath and bled a completely empty brake system.... (took fliping ages!!!!) but the brakes were bled finally **** hot!!!
    Drive shafts are installed and semi torqued down which was another step!
    Tuesday night wasn't too bad either.. this car came with the Hydraulic front engine mount (something I wasn't really interested in keeping + it was FUBAR) I did have a Solid Rubber Front mount also that I could have used but that would have been no fun!.. + After buying a Complete BFI Stealth Engine mount kit from Dubaddiction a few months back I was adamant I was going to use the whole lot!)
    My Cousin was In this evening we figured out what we were gonna do and cracked in to it... We butchered up the Factory Hydraulic mount to use it as a base for the BFI Insert to Seat on... once that was removed we found a High Tensile bolt that was almost thick enough and slid in to the centre of the bush. Parted off the head and drilled and tapped a M10 Thread right down the centre...
    Once that was on and we found the correct angle for the mounting bolt we layered on some heave Mig wire with some very deep penetration for good measure (haha wouldn't want to read that out of context)
    With Insert Seated on
    Going to paint it up today with some Por15 and we should be ready to start bolting everything back in for the engine!
    (engine aiming to be back in thursday night)
    This mount Modification is experimental... I'm not worried if it fails as it will just prompt a different attempt at modding!
    Front Wheels are on and car is back on the ground now too
    Check out my Camber bro!!!
    hahaha
    Also... Power Steering Lines are now brand new and Correct Lengths! Whaka yeah!
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
  5. #25
    Feb 2008
    New Zealand
    Short night tonight
    Front Engine Mount Painted up...
    Dash Board Semi in...
    Does anyone know where the Body to Dash Plug Clips or secures to.. I have long since forgotten
    - 2010 Golf R
    - 1997 Golf VR6
  6. #26
    Feb 2008
    New Zealand
    Not much further progress on the dash... Few more bolts in.. More wiring sorted/soldered
    Where the Frig does that monstrosity of a plug get tied away to? ^^^^^^
    Started assembling the Front Cross Members and Engine Mount and the Engine is Hooked up to the Hoist ready to be put in to place...
    New Hard Plastic Raintray cover installed too minor but yippee either way!
    - 2010 Golf R
    - 1997 Golf VR6
  7. #27
    Feb 2008
    New Zealand
    Well the Weekend netted some pretty good results...
    Engine is now back in and bolted up! Drive Shafts and all and the Cable to Hyro setup seems to be working fine too...
    Drove the car forwards 2 feet ha!
    The Front Engine mount Mod seems to have worked also!
    Spent the Rest of the afternoon adjusting cable lengths etc (as a few things have moved since before the gearbox swap.)
    All the Horribly Grey Cable Tubing I am slowly cutting off and replacing with Black Crinkle Tubing (much nicer and more flexible!
    Engine Starts and Runs and Idles like a Trooper
    Bit fricken loud at the moment with just the headers (no exhaust tube or mufflers)
    Hoping to drive it this week and get it all road legal...
    Just some more minor **** too also to get the Power Steering all plumbed up...
    - 2010 Golf R
    - 1997 Golf VR6
  8. #28
    Oct 2011
    Auckland, New Zealand
    Awesome work Anton! Are you around one evening this week? Keen to come and have a look!
  9. #29
    Feb 2008
    New Zealand
    Re: Mini Project: Save the Hooker... MK2 GTI 16v
    Quote Originally Posted by nacnud View Post
    Yea bro probably thurs and friday...
    As for last nights progress
    Fitter brand new hellas to the crash panel
    Power steering system setup.
    Fitted the radiator
    Ran up the system and let it bleed all thru...only to find the Radiator Fan thermo switch is leaking from the bottom off the crush washer.... fk sake.. new one of those tomorrow and do it all again...
    Oh yeah.... aligned the gear linkages
    And started fitting the crash panel
    Also the digifiz isnt registering watertemp... but the cooling system is working other than the small leak...
    - 2010 Golf R
    - 1997 Golf VR6
  10. #30
    Apr 2006
    Asaka-shi Saitama Japan (from Tassie)
    Awesome job!! Looking great.
    Cheers, Benny
    www.axesent.com.au
