Changed the Cambelt at lunch break today and bolted up the secondary part of the headers
Thanks Germanautoparts.com for the cambelt kit etc awesome service from that crowd..
A little progress this evening..
Subframe with Brakes etc basically ready to be re-installed
All suspended and installed... (just need to replace one of the Captive Nuts on the LHS for the subframe rear bolt.. its stripped unfortunately!
Nice Super Sprint Headers all bolted up to the Block and the Rear Engine Mounting Point!
killin' it dude! I"ll be over soon, so you'll have to give me the royal tour
Waiting for **** to arrive and having serpentine belt alignment issues grrr....
Sent via Tapatalk
Intake Manifold back from powdercoaters now textured black with colour matched inset letters (to the blue brake calipers)
All new Injector Inserts Seals and guides installed while it was all apart!
Fixed the fubarred captive nut for the subframe yesterday.. re mounted the subframe torqued it all up
Installed the Electric window regs and tested them!
Ran the loom for the electric windows
Removed the fender aerial and blanked that plug hole off..
Started welding up the rust hole in the door
Installed new CVs on the freshly powdercoated driveshafts but forgot to slide the rubber blancer thingy back on to it... ooops
Other **** i got powder coated!
Sent via Tapatalk
Nice, keep it up!
awesome thread mate, love your work and the lengths your going to. i like the little details on this and i'm sure it will be stunning when finished. keep the pics coming...
Just one last pic of the powder coating.. cos i think it just looks so damn sex...
The engine is edging closer to being re installed.. need the gearbox.. pick up new clutch and flywheel kit tomorrow..
Need to finish the wiring for the central locking and electrick windows and then the interior can start going back in!
And start fitting up various other bits and peices... sunroof seal.. new cable shifter etc etc...
Sent via Tapatalk
What am i missing from the back of this intake mani!?
Fitted the clutch
Oil change on the gearbox
And now the engine and gearbox are intercoursal again!
Oh yeah hooked up the new belts!
Sent via Tapatalk
Sent via Tapatalk
