Page 10 of 11 FirstFirst ... 891011 LastLast
Results 91 to 100 of 101
Thread: Mini Project: Save the Hooker... MK2 GTI 16v
  1. #91
    Jun 2007
    Eastern Suburbs Melbourne
    I meant taking 15mm off the rubber insert. requires a little bit of modification of the insert 'housing' (similar to what you did with the front one, with the drilling and tapping of the central rod)
    I've got a mk 3 subframe, (VR swap) and all I did was chop down the rear mount around 15 or 20mm.
    I used to have a mk 2 front engine mount (unmodified and standard) and modified the bracket (hybrid mk 2/3) to suit the 02A. Using the standard mk 2 crossmemeber. I found that the engine had unacceptable amounts of rock., ie when coming off the throttle at high rpm.
    I have since upgraded to a toledo/passat/corrado front crossmemeber (mk 2 fitment, but with a mk 3 mount system) and run a factory bracket (unmodified) with a mk 3 BFI insert. Much better, no issues with rubbing/knocking.
    i like volkswagens
  2. #92
    Feb 2008
    New Zealand
    Dyno Video from a while back.
    While the KR was still operational
    http://youtu.be/g2zaVNLOFAs
    - 2010 Golf R
    - 1997 Golf VR6
    - 1989 MKII Golf Diesel
    - 1987 VW Golf GTI 16V
  3. #93
    Feb 2008
    New Zealand
    Well
    Last weekend netted a few Changes for the better
    - Dropped the rear of the engine 16mm on both Sides ABF Clears bonnet now and no longer causes car to vibrate.
    - Nice Soft factory Rubber Hydraulic mounts. Threw out the Urethane Mounts
    - Converted the car back to Manual Steering and finally killed the notchy steering that has been plaguing this car since the Resto..
    and finally sorted the Leaking Flex Joint issue with the headers..
    Drives very well sorted now
    Also had a Chuckle when I Stumbled across these old picks again!
    Before
    Now.
    Its nice having the 5 Stud with Wide track and being able to use the MK 2 Manual rack.
    - 2010 Golf R
    - 1997 Golf VR6
  4. #94
    Dec 2007
    Perth, WA. *YAWN*...
    What did you do with the small bumpers and matching arches?
  5. #95
    Feb 2008
    New Zealand
    Quote Originally Posted by GOLFBALLS View Post
    Sorry it took so long to reply..
    I still have the bumpers stashed at a mates place. the arches are gone.. thou they were pretty poked from abuse...
  6. #96
    Feb 2008
    New Zealand
    Red face Small update: Another new Engine (ABF) and a 02A with a LSD...
    Purchased a Golf 3 16V last year with a Minter engine and gearbox as donor parts for the MK2.
    also got a 02A OBX LSD
    K-Jet had had its day, fed up with the hard cold starts in the morning and lumpy running (the lumpy running sounded awesome but it was kinda all show no go), I wanted Key turn reliability and Automated Ignition Timing & Monitored Fuelling
    Few stumbling blocks with the LSD install. Some tolerances on the new diff were slightly over sized. so a machinist buddy sorted that for me. but overall relatively painless and the gearbox went back together fairly easily.. drilling apart the old diff sucked ass..
    - New Bellevue washers (Cup Washers)
    - New 12.9 Diff Body Cap screws
    - ARP Ring gear bolts.
    - New Diff Bearings and Oil Seals.
    Didn't bother touching any of the other bearings.. the gearbox was tight.
    The old Kjet ABF coming out
    3 x 2 Litre 16V just chilling out...
    New Engine in
    I love spaghetti splicing CE2 in to CE1... Decided to strip back all the looms of their brittle plastic tubing. and re-clad in braid tube and re-route much of the wiring.
    Progress as of last night. Looms spliced, just need to install an additional relay now to power the o2 Sensor heater and injectors.. and figure out how the Rev Counter works on the Digifiz cluster...
    - 2010 Golf R
    - 1997 Golf VR6
  7. #97
    Jun 2007
    Good work!
    I don't envy you trying to convert from CE1 to CE2 though
    i like volkswagens
  8. #98
    Quote Originally Posted by ranton-inc View Post
    You used a piece of string to lift out the old motor? You're a braver man than me.
    Love the shot of the 3 engines. Some people are just so lucky..........
  9. #99
    Feb 2008
    New Zealand
    Yea ? and put the new one back in?
    that rope has lifted many of engine and gearbox combo...
    Several VR6s, and a whole bunch other ****... never a problem
    I think of it more as stupidity and wastefulness, such is life hahaha
    the odd looking 16v on the right is for another little resto I am starting soon....
  10. #100
    Feb 2008
    New Zealand
    Swap complete... drives beautifully. plain and simply good....
    - 2010 Golf R
    - 1997 Golf VR6
