Page 8 of 13 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 129
Thread: Mick's mk4 1.6 to 1.8t conversion
  1. #71
    Oct 2010
    Mildura, Victoria
    I know I'm going to get told off for doing this... But I may have removed the factory ecu boost controller... That's how it gets to 13psi
    '01 Mk4 Golf GL, Engine swapped to 1.8L GTi motor, Whiteline Swaybars, Nolathane & Pedders Bushes, K&N Oversize Pod Filter, 2 1/2 inch Cat back exhaust
  2. #72
    Quote Originally Posted by Clarkee_vw View Post
    Are you talking about the N75? So did you check the fuelling out afterwards? With the N75 disconnected it would normally run at actuator pressure which would be 5-6PSI.
  3. #73
    Oct 2010
    Mildura, Victoria
    I have a boost tee instead..
  4. #74
    Oct 2010
    Mildura, Victoria
    Also a rising rate fuel pressure regulator
  5. #75
    Explain to me what the boost Tee is doing Clarkee. The FPR might be saving you some big expense.
  6. #76
    Oct 2010
    Mildura, Victoria
    Boost tee controls the waste gate on the turbo.. Allowing you to increase or decrease the boost. They are from turbosmart..
  7. #77
    Manual Boost Controllers
    So is this the basic $100 or the posh $300 one? I was trying not to tell you off but dude this is 2012 and turbo control has moved on since they first came out. Back in 1985, bleed valves were all the rage on Ford RS Turbos and Renault 5 Turbos. When I was a kid
    Audi and VW spent more than a few dollars setting these up and I'll admit the AGU is far from the most sophisticated motor out there but a flash is by far the best way to make them go better and stay together.
    I know you have access to this stuff cheap through work but you gotta lay off it
  8. #78
    Oct 2010
    Mildura, Victoria
    Haha it's so tempting to buy stuff at work. I can get everything I need there lol
  9. #79
    Cold turkey that's what you need. A good couple of months in rehab and you'll come out like new LOL.
    Put the N75 back and sell the shiney stuff, then email me. Do it properly, you have spent lots of time getting the engine in, be a shame for it to give up on you.
  10. #80
    Oct 2010
    Mildura, Victoria
    Lol rehab
    I've gotten so used to the power though it lights the front wheels up at 60kmh in second gear..
    I'm saving to buy a gizmo electronic boost controller instead of the manual one..
    Also I've put Nulon 80,000km oil treatment in the engine oil which is the same as Slick50.. Puts a Teflon coating in the engine internals and the turbo. Also using special oil from Penrite that specific for the golf. I treat her right
