Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 92
Thread: Meet Ziggy - '79 GLD MK1
  1. #61
    I'll be tackling this soon Pete, thanks for the info
  2. #62
    Jun 2007
    Eastern Suburbs Melbourne
    Great info Pete
    Simple tips but true life savers once you get around to doing it!
    that's for sharing!
    i like volkswagens
  3. #63
    Jun 2006
    Orange NSW
    Biggest trick with replacing metal pieces like that is that
    YOU MUST MAKE THE REPAIR PIECE BEFORE YOU CUT OUT THE RUST.
    Make the repair piece a bit bigger than the rusty area and shape it to the same shape as the panel.
    Trace around it and cut the car to match the new section.
    If you cut the car first you'll never be able to shape and size the new piece.
    You can see some of my markings in the above.
    The other thing to point out which isn't obvious is that that welding is done a few mm at a time. You can't just lay down a bead. I probably pulled the trigger a hundred times on the above. You lay down one spot at a time , waiting for the spot you just welded to stop glowing red. It only takes about 1/2 a second for the weld to cool.
    You also need to watch the heat generally and not do too much at once or you'll distort the panel. A good panel beater will tap out the weld as they're going, using the residual heat to help with the shaping.
    I'm no expert by a long shot, there's still a skim of filler over my repairs, my friend Dennis who's slowly teaching me this stuff would have done all of this in metal only and have kept the shape and thickness of the metal perfectly.
    Pete
    Yeah that was one of the things I had to get my head around with playing with this stuff.. Because in my job, you preferably machine the pocket/hole etc before you make the insert, that way if you **** up, you can just make the insert a little bigger.
    Thanks for the info once again.
  4. #64
    Boronia VIC
    Brand new screen back in the formerly rusty hole.
    Added some new mylar too. This is the rare spares variety, not quite OEM but comes up pretty neat.
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  5. #65
    Aug 2006
    Melbourne VIC
    Much of the welding repairs on Ziggy were replicated on Josh's Mk1 today.
  6. #66
    Boronia VIC
    Nearly time for Ziggy to move on to his new owner.
    Finished the chin spoiler today after grinding off the welds that had come through the panel from behind where I'd had to reattach the cross member.
    7? MK1 Caddy
    12 Amarok
  7. #67
    Jun 2007
    Ziggy is looking pretty smart!
    now you'll be able to get stuck back into your projects! which is next? haha
    i like volkswagens
  8. #68
    nice work pete...love the way you car keeping VW's alive
    Velly
    '91 2.0 8v GTI
    Quote Originally Posted by DubSteve View Post
    I have wood thinking about you
  9. #69
    Boronia VIC
    Ziggy's off to his new home. Here's a a last few Photos.
    Ziggy will be making an appearance at DOVW and is all set now for it's next 500,000 Km.
    7? MK1 Caddy
    12 Amarok
  10. #70
    Nice restoration Pete! It looks really neat.
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
