Page 2 of 10 FirstFirst 1234 ... LastLast
Results 11 to 20 of 92
Thread: Meet Ziggy - '79 GLD MK1
    Oct 2005
    Nowra, NSW
    Awesome work Pete, we need more guys like you around keeping these old girls on the road
    Sep 2006
    Australia?
    Quality threads Mr Johns Quality threads
    Jun 2007
    Eastern Suburbs Melbourne
    Yeah, I was going to ask you if you wanted any of the diesel stuff out of this. Everything except the head and block should be OK. Even the glow plug fuse box is intact and has it's cover. There's also 1/2 tank of diesel I need a new home for
    Pete
    Ok, I'll come around next week end. I need to fiddle with the alt. bracket, mines mis-aligned.
    i like volkswagens
    Gosford Central Coast NSW
    aww pete, you keep fixing them up ... but you keep making them petrol
    good job saving another
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Oakleigh VIC
    Popped the motor in yesterday.
    Needed a new rear gearbox mount. Diesel has made the old one soft.
    Nothing remarkable with the fit up. This car actually had all the factory heatshields and brackets still on the downpipe.
    Exhaust is all hooked up. Need to clean up a DGV weber and pop it on during the week. Need to flush the last of the diesel out of the system too.
    Did all the gearshift linkages while I had all motor out.
    Had to replace a torn CV boot too.
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
    Oakleigh VIC
    Those red leads will get replaced before it goes back on the road, they were just what was lying about.
    While the car was up in the air I discovered one of the wheels was loose. I assumed at first the wheel nuts were undone the wheel rattled around so much.
    Turns out the wheel nuts are tight! Looks like I'll be replacing wheel bearings too!
    Pete
    7? MK1 Caddy
    12 Amarok
    Feb 2008
    Melbourne.
    great work Pete...despite having a great new rocket, you make the re-doing of my old motor look so easy !!!
    Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
    Oakleigh VIC
    Got the carby in yesterday. Took most of the day stuffing about with it.
    The secondary butterfly shaft was seized so I had to tear the thing down and clean a lot of stuff up. There were a few other little issues, like a bent choke flap, that I had to sort as well.
    When it came to fitting the manifold it turned out that I didn't have a full set of petrol manifold bolts so I had to cut down some diesel ones. (The bolt bar had shut by then).
    Of course the DGAV Weber hit the back of the rain tray too, so I had to do a bit of panel beating to even be able to get it in there. Matters were made more complicated by this carb having an water fed auto choke hanging off the back of it.
    I'll tackle the plumbing later today, there's going to be hoses all over the place!
    I made up a bracket and used the ball stud off the diesel pump so that I could use the diesel throttle cable. I came up really neat, much better in fact than the factory petrol cable setup.
    Pete
    7? MK1 Caddy
    12 Amarok
    Feb 2008
    Melbourne.
    looking forward to see how it runs Pete !
    I honestly wouldn't worry too much about the choke Pete.
    If they're tuned spot on, you shouldn't have any drama's with cold start up.
    None of my old carb'd cars ever had working chokes (most of them I deleted too) & I never had a problem with them setup like this.
    One - two pumps of the throttle & they'd fire up. You only had to hold the throttle for a couple of seconds to let the idle settle.
    If you really feel the need, you can retro fit a electric one to these carbs, which makes it a ton more easier & waaayyy more neater than running cooling hoses all over the place if the car doesn't have the intake manifold equipped with the choke water heater.
