Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 92
Thread: Meet Ziggy - '79 GLD MK1
  1. #41
    Oakleigh VIC
    Re-assembled the front bits today.
    Brakes need a good seeing to and I think I'll swap out the diesel front springs for petrol ones.
    Needs a good wash too
    Hmmm, still room for 2 more
    Pete
    7? MK1 Caddy
    79 B1 Passat Dasher Project
    12 Amarok
  2. #42
    Looks good Pete,
    You thinking about selling?
    Audi S3 8L - Stroker GTX3582 700bhp+
    Golf GTI 1980
    Golf GLS 1979
    www.facebook.com/etunersmotorsportau
  3. #43
    Oakleigh VIC
    Quote Originally Posted by 16v_kid View Post
    Nope! There's still room for 2 more!
    7? MK1 Caddy
    12 Amarok
  4. #44
    Coolies
    Golf GTI 1980
    Golf GLS 1979
  5. #45
    Jun 2007
    Eastern Suburbs Melbourne
    hahaha tin foil indicators. shocker.
    i like volkswagens
  6. #46
    Oakleigh VIC
    Had to move a few cars around the other day.
    The trailer was pretty grubby as we'd been sanding the passat up on it. Ziggy needed a wash too so we loaded up Ziggy and presure washed car and trailer together.
    Pete
    7? MK1 Caddy
    12 Amarok
  7. #47
    Oakleigh VIC
    Got stuck in to the front suspension today.
    Work completed.
    • Replace both front wheel bearings
    • Replace both front struts
    • Swap GLD springs for GLS springs
    • Replace bump stops and boots
    • Replace 1 outer CV boot
    • Replace 1 tie rod.
    It's going to need a set of pads too, I just found some cheap on e-bay
    Hubs and struts out.
    New bearings in
    This was caused by a loose axle nut! Now it's junk, luckily I had a spare.
    New bearing.
    7? MK1 Caddy
    12 Amarok
  8. #48
    Oakleigh VIC
    Torn outer boot.
    New boot!
    I used a couple of shocks recovered from a wreck, these were only a year old and still working fine.
    All back together again.
    7? MK1 Caddy
    12 Amarok
  9. #49
    Always tinkering around Pete.
    It never seems to stop.
    Do you put alittle bit of tranny/atf fluid eg. 50mm - 100mm in the shocker tubes at all?
    This helps keep the shocker cool & also helps with transferring shocker heat through the oil & onto the outer tubes & can also prevent shocker seizure in extreme conditions.
  10. #50
    Oakleigh VIC
    Quote Originally Posted by golfworx View Post
    Yep, although I just use engine oil. I just pour a bit in and dip the shock into it to see how far up the shock it comes. I keep adding oil untilit's about an inch from the top.
    I had one once which had been assembled dry what a PITA to extract that!. The rust grabbed it big time!
    Even 2 tonne wouldn't shift it!
    Pete
    7? MK1 Caddy
    12 Amarok
