It lives! Fired up no problems, just required a little twist of the dizzy and off it went.
Wiring next, it's hot wired at the moment.
Pete
Great stuff as usual pete!
I feel like posting your name in the 'things that get me inspired thread'!
BTW, I've NEVER seen a South African car with good wiring. They've probably all been stolen numerous times, rebirthed, crashed, rebirthed again...
Pete
7? MK1 Caddy
79 B1 Passat Dasher Project
12 Amarok
Good stuff, Pete.![]()
Children(VW) who have left home, among others:1966 VW 1300 Deluxe Bug(Harbour Blue)1966 VW 1300 Steel Sunroof Bug(Ruby Red), 1971 VW 1600 S Bug(White) 1972 VW 25th Ann. Bug(Avocado) 2000 VW Golf Mk IV GTI 3 door(Metallic Black Magic), 1985 VW Golf Mk 1 GLS Cabriolet (Metallic Gun Metal) Current: 1985 Mercedes Benz 280CE Coupe(Midnight Blue)
Bit early to tell yet, there's always a bit of smoke when you start up something like this. There's WD40 in the bores, residual diesel in the tank, diesel soot in the pipes and who knows what else.
Needs to go for a few runs before I'll really know.
Now that it's in I'll do some comp tests which will let me know more.
Starts really easily on the first turn and the water choke is operating perfectly.
Pete
7? MK1 Caddy
12 Amarok
Righto, got stuck into the wiring and found lots of interesting stuff.
Additional relay bases, Glow plug, rear wiper and boot unlock!
The boot unlock kit looks like a dealer option there's a a few OEM parts in the setup such as the relay base and solenoid cover.
7? MK1 Caddy
12 Amarok
I've got mixed emotions as I remove some of this stuff. Some of what I'm pulling out would have taken ages to put in and is actually pretty neat.
Take this for example. It took me a while to figure this out as I never had the diesel running and the electrics are all out of commission at the moment.
It would appear that someone needed a reminder to turn off the cold start.
It's a bit easier to see how it works once it's out. The toggle switch is a spring loaded momentary action type.
All that to drive this little LED
7? MK1 Caddy
12 Amarok
This switch was used to control the GTI driving lights I think. The grill didn't come with the car and it's going back to singles so the switch is coming out.
This switch under the dash near the driver operates the hatch release.
Mechanical brake light switch will stay.
I'm going to pop another console in, this one's got a few too many holes.
The lighter socket was just wired in parallel with the dash socket. The light was wired to the glow plug circuit.
This car even has a light in the boot!
Think I'll Leave the switch and find a nicer light to go in there.
7? MK1 Caddy
12 Amarok
I'm going to keep the clocks but move them into another fascia to get rid of the extra holes and fix up the red lenses over the warning lights. How's that for some mileage?
7? MK1 Caddy
12 Amarok
There's a number of owner improvements to this car worth mentioning.
Genuine Kamei door pockets!
Pop rivets cut off long used to retain shift boot in console.
Extended accelerator pedal.
This is stuffed now but it was a little divider to hold light items in the corner of the boot.
Seat belt hanger hooks in the rear. These look like they're out of a Kombi or something.
I'll bet there's a story behind all of these mods.
Pete
7? MK1 Caddy
12 Amarok
